ECUFlash / Evoscan / Mitsulogger Questions
Old Jul 4, 2014 | 03:04 AM
  #1561
evoscan's Avatar
Silver Sponsor
Originally Posted by RST_89
my fault there was a wrong metadata folder location!
big thanks to evoscan!
sorry
Glad to hear! you're welcome.
Old Jul 4, 2014 | 03:09 AM
  #1562
evoscan's Avatar
Silver Sponsor
Originally Posted by mines5
I am using evoscan 2.9 ,i open my hex file from the evoscan folder the load and rpm scales show correctly in the live map tracer but when ever i try to open a different hex file the load values and rpm show random numbers.
Kindly guide me through.
Thanks
sorry about that.. they are not actually random numbers, its just showing in Little Endian format instead of Big Endian format. i.e the 2 bytes are just swapped around.
EvoScan v2.9.0092 is now out to fix this.. press Check for Updates inside EvoScan under help.. this will correct the Load and RPM Axis showing correctly in the MapTracer.. Any problems, let me know.
Cheers,
Hamish.
Old Jul 4, 2014 | 04:59 AM
  #1563
matteclipse's Avatar
This is new to me, I can't get EcuFlash to flash in a new Rom, I keep getting an error message of EcuFlash could not recognize this ROM image using any of the current definitions. Please Help!
Old Jul 5, 2014 | 03:16 AM
  #1564
jungle's Avatar
Originally Posted by evoscan
after teamviewer your pc, I found there was:
multiple copies (x3) of your rommetadata xml folder, old versions of ecuflash and evoscan.
the actual fix was simple.. remove all the duplicate copies of rommetadata xml folders. install the latest clean verison of ecuflash with default XMLs
your ROM is 20030013 JDM Galant VR4.xml and it already comes default as part of the latest ecuflash.
I copied your kenneth mods xml into that file, and named it 20030013 JDM Galant VR4 Kenneth mods.xml
now you are all good to go! it works on both Ecuflash and Evoscan no problems at all.
Cheers,
Hamish.
Ha ha, thanks again Hamish you da man
Old Jul 6, 2014 | 12:27 AM
  #1565
aquaplane's Avatar
Hey all, got my very first tactrix cable, ecuflash software and evoscan software. All up to date. But I can't seem to bring up the map / image that is currently on my ecu.
I've an 05 ausdm evo ix that was tuned by someone else, what I want to do is read the current tune and edit it to suit my new perrin intake. I've been doing a bit of reading about MAF scaling etc which seems to be pretty straight forward. Although I'm having trouble reading the current rom that is on the ECU.
When I read the ecu, it saves a .srf file. And it doesn't show any of the data (fuel, air, timing etc). I've tried changing the format to .bin and .hex but they all don't show any data on ecuflash.
How do I go about reading the ecu properly so I can edit the rom?
Thanks
Old Jul 7, 2014 | 12:02 AM
  #1566
Charlescrown's Avatar
Can anyone help with a workable logcfg file for an JDM EVO7.
I cannot get my Tactrix OpenPort 2 to log directly to the sd card. All works great with Evoscan to a laptop.
Problem solved and it's working great. I named the logcfg file logcfg.txt.txt
Old Jul 15, 2014 | 09:46 PM
  #1567
ineedboostman's Avatar
ecmlink cable
Does anyone know if you can use an ecmlink cable with evoscan and ecu flash or do I have to buy an open port cable?
Old Jul 16, 2014 | 12:50 AM
  #1568
Jerra's Avatar
Have a Ceddy Evo5/6 ROM on my Evo 5 and EvoScan doesn't show me what map I am using, always is 0. Connections are OK and maps works well. Anything about this issue?
Old Jul 17, 2014 | 03:09 AM
  #1569
evoscan's Avatar
Silver Sponsor
Thanks
do you have a screenshot? I can't really understand what you are clicking on.
Old Jul 17, 2014 | 03:10 AM
  #1570
evoscan's Avatar
Silver Sponsor
The OpenPort cable is the only thing I know that can work with ecuflash.
Old Jul 17, 2014 | 03:19 AM
  #1571
evoscan's Avatar
Silver Sponsor
are you referring to this one? Map Switching Input, B2, x bit 5 ?
take a screenshot or reading of the "Port C" B2 to see what the raw data is from PortC
Old Jul 17, 2014 | 01:15 PM
  #1572
Jerra's Avatar
Yes!
Not sure what is Port C and how to see this data?
Do you mean data during logging in 3rd column "Reading"?
Thanks!
Old Jul 18, 2014 | 04:52 AM
  #1573
Jerra's Avatar
Thanks!
Found Port C, will inform you about data when logging ...
Old Jul 18, 2014 | 05:14 AM
  #1574
aquaplane's Avatar
Just wanted to update. Problem solved!
My ECU had a Tephra map on it, loaded up tephra v7 .xml and it opened right up
Old Jul 18, 2014 | 05:59 AM
  #1575
Jerra's Avatar
Here you go,
Map 0 primary
[IMG][/IMG]
Map 1 secondary
[IMG][/IMG]
