ECUFlash / Evoscan / Mitsulogger Questions
Old Apr 18, 2013 | 07:14 AM
  #1411
03lances's Avatar
Originally Posted by 03lances
Really late reply on this sorry. If it randomly cuts off I would say a loose connection or possibly a driver (computer driver not you ) issue when connected and logging.
Originally Posted by detroit pistins
I ended up figuring out the issue, it was hitting the "space bar" on the keyboard too quickly after finishing the run. I guess I needed to give it few more seconds to buffer the data before saving.
ps. for those that didn't know, hitting the space bar is another way to stop logging.
I guess it was a driver issue after all lmao
Old Apr 19, 2013 | 11:46 PM
  #1412
ApacheToYaDome's Avatar
I can't find the data.xml file in evo scan. I'm looking under:
ProgramFiles>EvoScan>EvoScan v2.9
Basically I can't find Evo Scans data.xml file anywhere, I'm using EvoScan v2.9 and EvoFlash
v1.44
Old Apr 20, 2013 | 12:17 AM
  #1413
07EvoIX's Avatar
it is in the my documents section
cheers
Old Apr 20, 2013 | 02:23 AM
  #1414
cheers
Thanks, I feel hella dumb now lol.
Old Apr 20, 2013 | 02:45 AM
  #1415
So I went into Documents>EvoScan V2.9>Data Settings and I still cant seem to find the data.xml file, I checked all the files and still can't find it. Could it possibly be under data settings> and under one of the mitsubishi xml files?
Old Apr 20, 2013 | 05:26 AM
  #1416
evo8426's Avatar
Mitsubishi MUTII EFI.xml is what is used now, it is still in the same location
Old Apr 20, 2013 | 03:01 PM
  #1417
Sweet, thanks!
Old Apr 25, 2013 | 09:41 AM
  #1418
T2Times's Avatar
Had a problem passing emissions .
Reason for failure- due to all obd readiness monitors being set to completed.
It has ecuflash. What can I do to have this pass emissions so I can register it already.
Old Apr 26, 2013 | 10:55 AM
  #1419
Lancer_Evo_8's Avatar
No Connection between EVOScan-Zeitronix ZT2
I have the Problem that when i made some test runs with the Evoscan Data Log i have no connection between Evoscan and my Zeitronix ZT2
On my Zeitronix i have the 3.5 bar sensor, Exhaust Temp. Sensor and the Wideband, but nothing of this Sensors gave someting to Evoscan. But i selected all this on the Evoscan.
Old Apr 27, 2013 | 05:04 AM
  #1420
sky_fr's Avatar
Did you set the zt2 com port in the Wideband menu ?
Old Apr 28, 2013 | 12:12 AM
  #1421
Where i have to do this?
Old Apr 28, 2013 | 12:45 PM
  #1422
Jarda_V's Avatar
Hi
the JDMMAP show constantly -14.5 :-( any ideas how to log boost in 88840016?
Thank you
j.
Old Apr 29, 2013 | 01:57 AM
  #1423
sky_fr's Avatar
On your screenshot, you can see a "Wideband (WB)" Menu, it should be there, I don't remember exactly, but it's not really hard to find. If you can't, I'll try on mine
Old Apr 30, 2013 | 01:00 PM
  #1424
Jarda_V's Avatar
How to log bost using EVOSCAN for 88840016
Hi
I have EDM Evo IX using 88840016 rom and OEM 3 bar MAP. I use evoscan 2.9 for logging parameters. My problem is in logging boost. Logging boost does not work. All suitable values are zero or static value. Can you help me with setting suitable formula or setting MUT table?
Thank you very much.
Jaroslav
Old Apr 30, 2013 | 06:40 PM
  #1425
shkettle's Avatar
ecu flash will only read from my ecu
i have recently took off my egr. i was going to make sure it was changed properly in the ecu. i had a battery charger connected, and read the rom. well it then said could not recognize the rom in its current definations. i tried to use the ecu unlocker but i dont think it is locked out. it is open port 2.0, ecu flash version 1.42
any help would be apreciated.
the attachment is the rom read.
File Type: bin
