ECUFlash / Evoscan / Mitsulogger Questions
Old Oct 12, 2015 | 02:54 AM
  #1651
mines5's Avatar
Originally Posted by evoscan
Hey mines, this is standard windows behaviour. if you move or delete the original .MSI installer file, then the windows subsystem can not repair any files in your c:\program files(x86)\evoscan\ folder
if you can't remember where you last left the msi file, and can't put it back. then you should just uninstall evoscan, and reinstall it. this time leave the msi file in the same place so that the msi auto repair can find it next time the files have been modified in the program files folder.. Microsoft designed it this way so that nothing can go accidentally go wrong with the programs protected inside the program files installation folder.
Thanks Hamish for the prompt reply, ill try to reinstall the evoscan again and let you know what happens. btw i am using windows 8.1
Old Oct 27, 2015 | 08:49 AM
  #1652
cyliew138's Avatar
Hi friend
i need evo 88770005 xml file and 89960000 xml file. download from web all not complete
thanks
Old Nov 13, 2015 | 07:12 AM
  #1653
dansan1988's Avatar
has anyone tried to download evoscan recently? I bought a cable and have a serial number and everything... But their website is not functioning very well and am unable to find an active link to download the software. Any help is appreciated, I have been trying all morning.
Old Nov 14, 2015 | 07:12 PM
  #1654
evoscan's Avatar
Silver Sponsor
thats because there are some old non-functional limitless.co.nz links floating around. just go to the evoscan.com website and download from their using your login. Also all yahoo email addresses are being blocked at the moment due to their crazy yahoo spam rejection rules. We are working on a workaround for both these issues at the moment and will be resolved one way or another.
-Cheers,
Hamish.
Old Nov 19, 2015 | 02:02 PM
  #1655
Lazyfong's Avatar
What do I need to do to make evoscan to log PSI Boost Error?
Found out how add PSI Boost Error from Raptord.
Here is the xml entry for evoscan. The forum won't let me paste it with the opening and closing tags, so you'll need to add a "smaller than" sign at the beginning and " />" at the end.
DataListItem DataLog="Y" Color="" Display="Boost Error" LogReference="BoostError" RequestID="8A" Eval="0.0241*x-3.087" Unit="psi" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-5" GaugeMax="5" ChartMin="-5" ChartMax="5" ScalingFactor="1" Notes="" Priority="1" Visible="false"
Last edited by Lazyfong; Nov 20, 2015 at 10:21 AM. Reason: Raptord gave the answer
Old Dec 12, 2015 | 10:00 PM
  #1656
SnailSpeed's Avatar
Not sure if this is the correct place to ask but i'm trying to set up my mut table for logging in evoscan. The car is an 05 gsr, rom id is 96940011. According to the table on page 157 of this guide:http://www.evoscan.com/ecuflash/Merl...UIDE-V1.7a.pdf to set up 2 byte load for example i'm supposed to change mut 00 to 899a, well in my rom mut 00 is FFFF. From what I understand the cells in the mut table that have FFFF are to be left alone. So i'm wondering if I need to do something else to the rom or maybe the information in the pdf is incorrect?
Old Apr 24, 2016 | 01:12 AM
  #1657
mines5's Avatar
Hi,
Just re installed evoscan 2.9 , having an issue with live tracer.
When hitting boost load doesnt go past 260 while viewing the values live. As soon as a stop live tracer and view the logs offline i see correct values in the tracer. I found that load 1 byte value wasnt set properly.
Please advise on this issue.
Old Sep 24, 2016 | 12:07 PM
  #1658
mines5's Avatar
Hi,
I am trying to add definitions to MUT II Efi file to log OMNI 4 bar but it doesnt seem to show the added item.
I think i am doing some thing wrong.
I want to log Omni 4 bar KPA , Omni 4 bar Psi and Gm IAT..
Please advise.
Old Sep 25, 2016 | 08:07 PM
  #1659
D-VO's Avatar
I would instead attempt to add the definitions to Evo scan when the application is open.
Old Sep 25, 2016 | 11:16 PM
  #1660
mines5's Avatar
Can you please post your values for Omni 4 bar kpa , omni 4 bar psi and gm iat ?
Request id -
Eval -
metric eval -
gauge min and gauge max -
chart min and chart max -
response bytes -
scaling factor -
Old Oct 15, 2016 | 08:32 AM
  #1661
mines5's Avatar
How do we remove this error ?
Old Oct 15, 2016 | 09:23 AM
  #1662
CDrinkH2O's Avatar
Go edit the XML and fix the error explained in the message. Add the missing space before the "a" of "address"
Old Oct 15, 2016 | 09:58 AM
  #1663
mines5's Avatar
I dont have an XML editor and i dont know how to edit it.
However, i have tried to edit it through note pad. I have fixed 4 xmls with [ no space ] before "address" still displays the error for the XMLs which are ok and have space before " address "
Please advise.
Old Oct 15, 2016 | 12:07 PM
  #1664
CDrinkH2O's Avatar
1. Download and install NotePad++.
2. Open the XML file in Notepad++ with the error from C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ <insert_your_xml_filename>.
3. Go to the line and character position in the file that was indicated in the error message.
4. Add the missing space before the address
5. Save the XML file
6. Restart Ecuflash
7. Reopen the ROM that uses the XML file you just fixed.
If that doesn't solve the problem then you have updated the wrong XML file.
Old Oct 15, 2016 | 01:00 PM
  #1665
mines5's Avatar
6. Restart Ecuflash
Instead i removed those xml files which had space problem.
No more stupid errors.
Thank you very much for the help . Cheers
