ECUFlash / Evoscan / Mitsulogger Questions
Old Aug 10, 2007 | 09:35 PM
  #286
BerserkerX's Avatar
Originally Posted by codgi
Check your baud rate. By default I believe its 15625. This sounds like exactly what happens when it is too high.
if the baud rate is to high or low could i possibly change it to where it needs to be without anything bad happening and why would this change it was working fine then i closed the program then reopend and tried to read again and then it just started doing that and no i didnt flash or anything just closed out evoscan. BTW thanks for the input already.
Old Aug 10, 2007 | 09:38 PM
  #287
BerserkerX's Avatar
NVM thank you just took a chance and changed the baud rate and it works fine now thank you so much i was panicing so thanks again codgi you are a life saver
Old Aug 10, 2007 | 10:30 PM
  #288
codgi's Avatar
Yeah sorry I didn't see that question until after .
The text box actually just needs a stray number to go in there and it will remember it. It really should display as a read-only box and only if someone clicks on some hard button (change baud rate) then should it allow itself be edited. I seem to remember debug mode for Wideband also changing the value but oh well just watch out for it in future.
Old Aug 11, 2007 | 05:13 AM
  #289
DanInPA's Avatar
How can you capture "2-byte Load" using MitsuLogger? Does anyone know how to alter registerID.xml to make it work?
MJ had it on other thread: Add below to the MitsuLogger registerID.XML file
<Request LogReference="requestID00" RequestID="00" Eval="x" Unit="INT" Logged="y" Response="2"/>
<Request LogReference="requestID01" RequestID="01" Eval="x" Unit="INT" Logged="y" Response="2"/>
<Request LogReference="2ByteLoad" RequestID="FF" Eval="((256*requestID00)+requestID01)*10/32" Unit="2byteLoad" Logged="y" Response="2"/>
Also, don't forget the 2-byte load setup on other thread where you need to flash your ECU with different set of number...
Old Aug 14, 2007 | 11:31 PM
  #290
UCB's Avatar
UCB
anyone log both a ZT2 and evoscan at the same time (err, meaning using the WB input of evoscan)? Im using a serial to usb adapter (COM 5), but when I try to log via evoscan it doesnt work, get a "unable to open port" error, or the signal get get fubared and it wont log at all
any ideas?
Old Aug 15, 2007 | 08:03 AM
  #291
TTP Engineering's Avatar
I have never seen a benefit in logging ZT2 afr to evoscan. Logging them concurrently at the same time on both loggers is the best way to obtain data.
Old Aug 15, 2007 | 09:51 AM
  #292
UCB's Avatar
UCB
Im lazy and havnt hooked up the rpm input to the ZT2, so logging in evoscan gives me rpm reference
Old Aug 15, 2007 | 10:00 AM
  #293
Its one freakin wire, green to green on the 2nd harness plug, lower row, 2nd wire to the right.
Do it... Do it now!
Old Aug 15, 2007 | 10:15 AM
  #294
UCB's Avatar
UCB
Im not sure where the harness is, and getting to the green wire will require me to rip my center console out since thats where I mounted the brain
Old Aug 19, 2007 | 08:30 AM
  #295
chrisw's Avatar
up
Old Aug 22, 2007 | 05:43 PM
  #296
R. Mutt's Avatar
This question pertains to Evoscan 1.0 Alpha.
Today I logged a Lancer Evolution VII GSR. Everything logged fine except 2Byte Load:
Why are the readings so off? The car was feeling down on power but I didn't see anything wrong in the logs.
Here is a copy of the log for assistance: http://download.yousendit.com/7E27787E72F994B4
Old Aug 24, 2007 | 10:15 AM
  #297
SoCalRedLine's Avatar
problem with evoscan:
Was using it to log WB with my LC-1...unclicked it last night (cause i didnt feel like connecting the LC-1 to the laptop) to do some timing tuning.
When i clicked back on the WB, it only reads 1-5v...not the actual AFR's anymore.
I didnt change anything in the .xml.
The LC-1 still works fine with all the other programs, Logworks, Mitsulogger, etc...
p.s. using Evoscan v.99
Old Aug 24, 2007 | 10:48 AM
  #298
I found a few threads that address the same problem...but i already checked gas type, and its set on Gasoline. The LC-1 works fine with Logworks.
https://www.evolutionm.net/forums/sh...n+LC-1+problem
https://www.evolutionm.net/forums/sh...56#post3842556
Old Aug 24, 2007 | 12:53 PM
  #299
:bump: ...its still doing it. anyone have any insight?
Old Sep 10, 2007 | 02:11 PM
  #300
andenbre's Avatar
my v1.0 is logging lc1 afr fine
