ECUFlash / Evoscan / Mitsulogger Questions
Old Apr 9, 2010 | 04:56 PM
  #751
metalsaber's Avatar
Originally Posted by geevolution
Ended up downloading evoscan, I thought ECUflash had the DTC reader lol. Pulled the code, turns out it was the P0507, I noticed the higher idle last week when I got the car back. The dreaded P0300 is now gone.
Now which one of these programs (ECUFlash or EVOScan) would I use to lower the idle?
ECUFlash
Old Apr 10, 2010 | 08:25 AM
  #752
geevolution's Avatar
Originally Posted by metalsaber
ECUFlash
Tried a search, couldn't find instructions on how to do it.
Old Apr 20, 2010 | 08:26 AM
  #753
voidhawk's Avatar
speaking of idle ... I have a question about the ISCV tables. For the "AC off" there are two tables (neutral and drive). How does the ECU switch from one to the other - is it based on the clutch switch (clutch in = neutral, clutch out = drive) or the speed sensor (speed zero = neutral, speed > zero = drive) or some combination of both?
Old May 3, 2010 | 09:43 PM
  #754
irishone337's Avatar
I have a incredibly noobish question about EvoScan. Let me lay it all out for you guys. I have the newest version of EvoScan with a Tactrix 2.0 cable. When I open up the program after the cable and everything is connected and I tell evoscan I'm using the 2.0 cable, what sub category should I choose before I pick the Ecu I'm trying to log.
When I select 2.0 cable, Mitsubishi/MUTIII it doesn't allow me to log RPM. Which is kind of a huge pain. Any input on this is appreciated beyond belief. I can build a motor but I can't seem to get the hang of this tuning thing yet. Granted I just started tinkering with it less than a week ago, lol, but that's what I have you guys here for right?
Old May 3, 2010 | 10:26 PM
  #755
PlanoEvo's Avatar
For some unknown reason evoscan 2.7 and an earlier version wont log fuel trims while out driving tonight. I am running tephra V7. Is anyone having a similar problems?
Old May 4, 2010 | 01:22 PM
  #756
HighwayStarX's Avatar
Just want to make sure this is the correct information you need to add to your rom in order to allow you to disable the p0300 code. Am I correct?
<scaling name="blobbits" storagetype="bloblist" storagebits="1">
<data name="0" value="00"/>
<data name="1" value="01"/>
</scaling>
<table name="ECU Periphery00 (F9A) Bits" category="ECUPeriphery" address="f9a" type="2D" level="2" scaling="blobbits">
<table name="Periphery Bit Number" type="Static Y Axis" flipy="true" elements="16">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery0 (FAA) Bits" category="ECUPeriphery" address="faa" type="2D" level="2" scaling="blobbits">
<data>bit.15</data>
<data>front o2 sensor heater circuit </data>
<data>bit.13</data>
<data>bit.12</data>
<data>Disable EGR / Enabled Ign Adv (set bit=1)</data>
<data>timing knockdown on light acceleration and less than 3000rpm</data>
<data>Enable Warmup Ign Retard</data>
<data>bit.8</data>
<data>Enable High Oct Ign Map Lookup (and many other subroutines)</data>
<data>"WG solenoid? Enable Speed Limit Test"</data>
<data>bit.5</data>
<data>for full time open loop set to 0</data>
<data>Immobilizer (1=enable 0=disable)</data>
<data>bit.2</data>
<data>rear o2</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery1 (FBA) Bits" category="ECUPeriphery" address="fba" type="2D" level="2" scaling="blobbits">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>2nd thermo fan table</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>Lean Spool</data>
</table>
</table>
<table name="ECU Periphery2 (FCA) Bits" category="ECUPeriphery" address="fca" type="2D" level="2" scaling="blobbits">
<data>P0443, P0446, P0403, P0243, P0090, P2263</data>
<data>P0450, P0451, P0452, P0453 Evap</data>
<data>P0441, P0442 Evap</data>
<data>bit.12</data>
<data>P0031, P0032, P0037, P0038</data>
<data>P1400 MAP Sensor</data>
<data>P0401 EGR Test</data>
<data>P0506, P0507 Idle Test</data>
<data>P0170 (P0171, P0172)</data>
<data>P0134 Front O2</data>
<data>P0300; set bit.4 and bit.5 to 0 to disable</data>
<data>P0132, P0136 O2</data>
<data>P0133, P0159</data>
<data>P0421 not in FSM</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery3 (FDA) Bits" category="ECUPeriphery" address="fda" type="2D" level="2" scaling="blobbits">
<data>P0128 CT Below Reg</data>
<data>P1603 Battery Backup</data>
<data>bit.13</data>
<data>bit.12</data>
<data>P0180 - P0183, P0461, P2066 Fuel Sensors</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>P0551 PS Pressure</data>
<data>P0500 Speed Sens</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>P0234, P0243, P2263</data>
<data>P0510 not in FSM</data>
<data>P1715, P1750, etc</data>
</table>
</table>
<table name="ECU Periphery4 (FEA) Bits" category="ECUPeriphery" address="fea" type="2D" level="2" scaling="blobbits">
<data>P0140 Rear O2 No Act</data>
<data>P0069 MAP vs Baro</data>
<data>P0111 IAT Circuit</data>
<data>P0554 PS Press Sens</data>
<data>P1530 A/C1 Switch</data>
<data>bit.10</data>
<data>bit.9</data>
<data>P0830 Clutch Pedal Circuit</data>
<data>P0090 Fuel Pressure Circuit</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
Old May 5, 2010 | 05:31 PM
  #757
jrsimon27's Avatar
tried to log today using evoscan 2.6 with a 1.3 cable and on an evo8 2004 with injectors 1000cc the baud rate was set at 10600 i think and it nevered log so i changed the baud rate to 15000 and it logs but the data it shows doesnt even come close to real data any help with this please
Old May 13, 2010 | 04:23 PM
  #758
RussK3's Avatar
I Just got my Evo 9 tuned and I was dissapointed in the numbers. dyno dynamics dynamometer. 22psi, whp was 281.6 and torque 298. seems a little low. I have a injen intake, nisei fmic. uicp and lower incp, perrin high flow cat. perrin downpipe. hks ti carbon exhaust. Hallman mbc, and deatschwerks 750cc injectors, walboro 255lph. when they were done tuning I started my car to leave and it was knocking. found out they injectors they just installed 2 of them were loose. could this have effected the tuning thus less horsepower? my cousin has the same exact set up minus the injectors, tuned at the same place and has 337 whp and 365 torque. any suggestiions? boost leak?
Old May 14, 2010 | 05:03 AM
  #759
dawnduran's Avatar
I have problems with evoscan too.
Before I install the new ECUFLASH 1.43.3000 (beta) inklusive Firmware Update of my OpenPort2.0 it works. After I install it, the evoscan 2.7 beta didn't find the OpenPort2.0 cable via USB.
Other programs works. For example PCMSCAN and ECUFLASH itself.
Old May 19, 2010 | 03:29 AM
  #760
ms_logging's Avatar
hi i could not log injector duty cycle with evoscan 2.7 on my evo5 . but evoscan 2.6 logging fine. any ideas ?
Old May 23, 2010 | 02:07 PM
  #761
kiley_sean's Avatar
Tried to search for this problem..
I finally got Evoscan to sync up (turned out I needed to change the BAUD rate). Thanks, Tkklemann.
Problem:
I do a data log, pull it up on maptracer, load my hex and it seems like there is a gap in datapoints from like 4500-7000 rpms. It's just blank..nothing. Anything below 4500rpm and after 7K rpms shows up fine and dandy.
I tried:
- Reduce the amount of parameters to log
- Set my laptop (lennovo) power settings on max performance
- Did one pull very slowly from 3-7.5K rpms.
Still have a gap in data from like 4500-7000rpm.
Anyone else have this problem?
Old May 27, 2010 | 06:21 PM
  #762
I need help with connecting my LC1 to EvoScan. I've searched around but my problem is a bit different. I'm running windows 7 64 bit on my laptop. I found the correct driver for my Dynex serial to USB adapter. When I open EvoScan and select the correct com port, I still get nothing. When I select LC1 wideband 02 e8 Mod I can't get a reading. What am I doing wrong?
Old May 27, 2010 | 06:31 PM
  #763
30lbsboosted's Avatar
can some one please walk me through how to setup for speed density im from ct and no tuners will do stock ecu speed density,i know i need a 4bar map sensor and iat sensor,but i need to know the pins at the ecu or what wires to connect them to and also how do you find and download the rom you need
thank you
Old May 27, 2010 | 08:35 PM
  #764
JFuego777's Avatar
I had a similar problem with my LC-1 earlier this week, but with vista 64 and a radioshack cable. What I had to do was use logworks 3, hit connect with the vehicle running, once i did this once, it set up the lc-1 and it logs in evoscan. Give that a try.
Old May 31, 2010 | 02:50 AM
  #765
GottaZtt's Avatar
Hello Sir,
I am a tuner in saudi arabia, and usually deal with standalone computers, but i have been approached by several people that want to tune their stock ecu's
I got the OP 2.0
i have both softwares 1.42 ecuflash and 1.34
i downloaded aktive matrix ecu unlock.
first i used the cable and i pulled the file fine.
but i open it and i cant edit anything.
all i can edit is the immobilizer (6E2F) and init code (0001)
thats about it
Rom info:
make: mistu
submodel: evo 7
market:jdm
year:2001
internal ID: 99860002
any help would be appreciate
thank you
