ECUFlash / Evoscan / Mitsulogger Questions
Old Jun 4, 2010 | 04:35 AM
  #766
aussie evo 8's Avatar
unknown ROM image
hi guys just got my tactrix cable and downloaded ecuflash i can download the map but carn't view the rom file i'm a noob to this software can any one help
evo8
jap spec
2005
manual
Old Jun 4, 2010 | 04:53 AM
  #767
metalsaber's Avatar
Did you 1.) Save the ROM to your computer? If not, you need to do that.
2.) When you saved the ROM to your computer, did you click File -> Open ROM?
Old Jun 4, 2010 | 09:47 AM
  #768
absubtle's Avatar
I pulled a rom image from a 2010 Evo X. No definition files found. Just wondering if anyone has any ideas?
I cant attach a .HEX file here.
Old Jun 5, 2010 | 01:48 PM
  #769
Dallas J's Avatar
Veteran: Army
Just got my stuff for ecuflash and evoscan but got a few issues.
ECUFLASH:
First of all, the cable I'm using is the old 1.3u (1 wire going to the white connector branching off to three pins) bought in either 06 or 07 by my roommate. As far as Ive been able to tell, I cant use this with the newer versions of ecuflash, and only have been able to get it to work with 1.29.
That would be fine except the file viewed from 1.29 has something crazy going on with the scale. Opening it in 1.42 views it just fine. My only idea is that 1.29 doesn't work quite right with 64-bit windows?
Do I have any options here or is my combination of cable and laptop just gonna cause me problems?
EVOSCAN
I bought and download EvoScan this morning. I'm guessing for Device Setup I need Mitsubishi MUTIII. This seems to work, but did disconnect twice while sitting in my driveway. Although I could have been connected with the car off, don't remember for sure.
The problem I'm having is checking DTC's. I'm not sure which DTC Method I need, but using OBDII Efi ends up giving me an error of "Arithmetic operation resulted in an overflow". Once that happens logging stops working as well, but restarting the program fixes that.
Also, right now I'm trying to get through emissions only being stopped by rear o2, catalyst, and rear o2 heater checks not passing. I turned that stuff back on in the flash but now I want to check that they've set before I go back. Is their a way to check these with evoscan?
Old Jun 5, 2010 | 02:10 PM
  #770
JohnBradley's Avatar
Dallas, there is forced OBD2 pass that we can do. You'll need to add the xml listed in the thread of the same name. Make the changes as outlined and flash the car. From that point on its like LinkV2 it automatically does it no questions asked.....
Or come up to the shop and I'll do it for free since I was the last one to tune Jesse's car.
Old Jun 5, 2010 | 02:21 PM
  #771
Dallas J's Avatar
Veteran: Army
That's pretty much what I think Ill have to do, I just was hoping I could check myself to see if they're set before I take the time to go back to DEQ
Old Jun 5, 2010 | 08:44 PM
  #772
Last time I touched your car this wasnt something that was available. The other option is if you didnt want to come to the shop email me the ROM and I can change it and send it back. I know the satisfaction of doing it yourself though so if you search for the forced pass thread it will let you know what to do.
Really its pretty easy stuff. Call me if you need to.
Old Jun 5, 2010 | 11:46 PM
  #773
kiley_sean's Avatar
Bump. Can anyone give me some advice (post 763)?
Old Jun 6, 2010 | 12:40 AM
  #774
There is 2.3 seconds missing. Is it losing connection and re-init or something? Or you have been abducted by aliens while tuning...not sure.
Old Jun 6, 2010 | 11:54 AM
  #775
yokozuna's Avatar
Noob here needs your help. I have tactrix cable 2.0, last ecuflash Version 1.42.2595, evoscan 2.7 beta 5, Innovate LM-2 wideband, HKS EVC 5 boost control. So, i searched i think enough to find a way to log AFR from my LM-2 to evoscan but didnt figure out how. Also, i dont understand how to log boost from my EVC to evoscan. These are major problems to me to keep on tunning my EVO 8 AUS market ECU ID: 96530006. If you can please help me i would apreciate that.
Old Jun 9, 2010 | 11:16 AM
  #776
EvoSeanzie's Avatar
I want to try and log for an etune, but I have a plx wideband unit. Does evoscan work with this?
Old Jun 13, 2010 | 08:47 AM
  #777
yeah mate tried that but i cannot view or adjust maps and if i try to view in 3d evo scan shuts down...any other ideas ??? i even reinstalled evoscan
Old Jun 17, 2010 | 10:50 AM
  #778
newcomer81's Avatar
Quick question about pulling an evo9 Rom.
I have an OP2 cable that i use all the time successfully with my 10. A local guy wants to get an e-tune and asked that i pull his current rom to be mailed out. I am assuming, but want to confirm that the read process for the 9 is the same as the 10s?
Old Jun 17, 2010 | 11:08 AM
  #779
metalsaber's Avatar
Yup. Just select the 9 when reading the ROM.
Old Jun 17, 2010 | 11:18 AM
  #780
newcomer81's Avatar
appreciate the quick response
