How much longer until evoscan .98
Old Jan 23, 2007 | 08:28 AM
  #31
jfitzpat's Avatar
Originally Posted by nvr2fast
Bump from a paying customer for Evoscan .98 with road dyno function!
Well, if you have any Innovate products you could LogWorks as a free stop gap. Use the free plug-in I wrote to log from your tactrix into Logworks (along with any Innovate gear generated channels).
Right click on the RPM trace and select "Smooth". Set a couple of ticks of smoothing.
Highlight the WOT portion of your 2nd or 3rd gear pull.
Select tools/calculation, and paste in this formula:
?Vehicle weight in lb = m[3000]
?Tire diameter in inch = td[25]
?Gear ratio of run = gear_ratio[1.21]
?Final drive ratio = finaldrive[4.53]
?i Name of RPM channel = rpm[RPM]
?Frontal area of vehicle (sqft) = Ar[30]
?Drag coefficient = Cd[0.45]
?Current atmospheric pressure (inHg) = atmp[29.92]
?Current temperature (degF) = temp[94]
#SAE correction factor
SAEcf = (1.18 * ((29.235/atmp) * sqrt((temp + 459.67)/536.67)) )- 0.18
#air density
density = 0.0412236 * atmp/ (temp + 459.67)
# tire radius in ft
R = td/24
# acceleration in g
a = slope(RPM) * pi * td * 4.3153245 * 10^-5/(gear_ratio * finaldrive)
# speed in ft/sec
v = (RPM * R * pi ) / ( gear_ratio * finaldrive * 30)
# aerodynamic draq in lbforce
Fa = 0.5 * density * (v^2) * Ar * Cd
# Accelerating force (lbforce)
F = m * a + Fa
# engine torque
trq = F * R * SAEcf/ (gear_ratio * finaldrive)
MC(torque;lbft;0) = trq
MC(power;hp;0) = trq * rpm/5252
You'll be prompted for some information (just like you would in any other street dyno application), and then two new traces will be added to your log.
The portion of the torque and power traces inside your selected section are what you would be interested in.
This is power from RPM with SAE correction. I've put power from speed and accell in another post in this thread.
Good Luck,
-jjf
Old Jan 23, 2007 | 09:06 AM
  #32
MRadjahoe's Avatar
So .98 is out? I didnt get an email!
Old Jan 23, 2007 | 10:44 AM
  #33
evo4mad's Avatar
I've been programming EvoScan all day today, out one day soon.
I'm still spending about 4 hours a day searching for a source for the connectors.
Old Jan 25, 2007 | 07:50 PM
  #34
coolguycooz's Avatar
So we are still waiting.
Old Jan 27, 2007 | 06:20 AM
  #35
evoxsi's Avatar
so whats the new eta on this
Old Jan 27, 2007 | 06:32 AM
  #36
MalibuJack's Avatar
You guys are harsh..
Programming isn't always about a few hours of coding.. There's coding, testing, fixing, recoding. Give him time, he'll get there. Sometimes the hardest part of coding is getting the motivation to sit down and do it. Happens to me all the time.
Old Jan 27, 2007 | 09:00 AM
  #37
3gturbo's Avatar
I am perfectly happy with the current tools available
Old Jan 27, 2007 | 05:05 PM
  #38
nah im not trying to be harsh and expect it to be out now.
its just that, (im not holding this against him or anything) i asked him if he could give me a ball park on when .98 would be out this was way before chrismas.
he told me, ill probably get it out by chrismas or a little after, as a sort of a chrismas present for you guys.
and its kind of almost february of next year.
but now im not trying to push him, im sure hes super busy with everything else in his life, but it would be nice to have .98
Old Jan 28, 2007 | 05:26 PM
  #39
C6C6CH3vo's Avatar
Here's motivation:
What release will happen first, Mitslogger1.5 or Evoscan0.98?
JK
Take your time folks, I don't even have the LC1 fully installed yet
Old Jan 28, 2007 | 08:27 PM
  #40
mchuang's Avatar
You think that is something haha I been waiting for the SRVIDZ EVO DVD TO RELEASE that was suppose to come out in OCTOBER and guess what it is now feb almost of the next year lol. I paid in august, but it is all gravy long as they dont forget I paid and I get the DVD sometime this year haha
Old Jan 30, 2007 | 07:04 PM
  #41
MalibuJack's Avatar
Originally Posted by evo4mad
MJ, that site doesn't have the connectors. Anybody else know where to locate them from?
Sumitomo F(6244-5121) 12-way connector
http://forums.openecu.org/viewtopic.php?p=4552
The male counterpart is M(6244-1121) Unfortunately it was only produced for Mitsubishi Motors and doesn't show up in their catalogs, but you can contact them directly to see if they have samples or if they can make a production run.
www.sws.co.jp
Not only did I find the part number for that, but I also found the part numbers for the Boost solenoid connectors (male and female), MAF connector (Male and female), Coil connectors (male and female) among many others.
Old Feb 4, 2007 | 02:39 PM
  #42
evo4mad's Avatar
I contacted SWS in Tokyo, they are $21USD for a pack of 100, F(6244-5121). 21cents each
Old Feb 4, 2007 | 04:29 PM
  #43
MalibuJack's Avatar
Nice.. I knew they had parts that weren't documented on their website..
Old Feb 4, 2007 | 06:20 PM
  #44
RazorLab's Avatar
MJ, you have PM, care to share the part #'s or tell me where to find them?
Thanks in advance!
EDIT
Are the part #'s:
6188-0624 (female)
6189-0264 (male)
Old Feb 4, 2007 | 06:28 PM
  #45
tuning g's Avatar
so it does subarus also that will be great
