Mitsulogger v1.5 Alpha featuring Wideband Support!!
ZT2 working here... Program crashed a couple times on me but I'd like to do a fresh XP build and start over... long overdue on this laptop. I did get a couple good logs... but not enough to really get into anything specific.
I'll bet your not using the RPM signal input on your ZT2...
MJ - Any chances of adding PLX support? I am using a M-300, which has linear analog output of 0-5 volts. Not sure if this can be implemented to be read by the Taktrix cable or not.
As far as I know, the M series PLX devices only have an analog output.. Not something that can hook up to a computer. You can hook up the PLX to an ECU+ and log AFR along with other engine data (I love the ECU+ by the way)
But the short answer is No, mitsulogger does not work with the PLX M-300 Its actually a physical limitation of your wideband not being able to be hooked up to a PC without external third party devices.
I've got a lot of reading to catch up on... I'm sure it's been covered but I need to get the injector scale/voltage saved after program close. I think I am.. at least the RPM is logged with the zt2 software. If there is anything I can test or help out with shoot me a PM!
Andy
It should properly save the settings if you close the program with the Exit button.. I inadvertantly forgot to include the correct shutdown code if you click the [x] button.. All of the settings are persistent except for Demo mode.
-jjf
Yeah I found it in my spam box.. For some reason since you sent it as an executable it tucked it away as a suspicious item, but Outlook won't let me retrieve it. I was going to reply to you yesterday when I noticed it was in there.
I hadn't even noticed it until someone else pointed it out. I had made a change in one of my test versions for debugging purposes which disabled it when you hit the X (so I could test if I could alter/change the location of my configuration settings) and forgot to "put it back" LOL
Do you need me to resend as a ZIP or something?
I wanted to confirm that the AEM Wideband WILL be supported in the release of 1.6 Beta
Nolimit Motorsport was gracious enough to get an AEM Gauge Wideband unit to me at a steep discount so I can put the code together. In the process I also will make up serial cables that they will be reselling in the future.
Innovate support is a bit more difficult as I am trying to support the protocol properly, so that won't make it into 1.6, but rest assured that when support does appear, it will log any of the Innovate MTS protocol stream products.
