Stock timing/fuel maps...
Old Feb 5, 2007 | 05:28 PM
A418t81's Avatar
Originally Posted by Mellon
whatever dude, the car was nose diving when it got into that kind of knock, that's a horrible tune.
If your car is literally "nose diving" with 10 counts of knock, then you have other issues.
Old Feb 5, 2007 | 05:36 PM
nj1266's Avatar
Originally Posted by A418t81
If your car is literally "nose diving" with 10 counts of knock, then you have other issues. Either way, go ahead and tune for zero across the board and have fun getting beaten
Two things:
1. a car can nose dive with 10 counts of knock. If 3 counts pull one degree, then 10 will pull 3 degrees. You are WOT @ 6000 rpm, your target map is 9 degrees and you get 10 counts of knock. You just had your timing pulled back to 6 degrees. That will cost you power.
2. Why would someone race an Evo on pump gas? When I am on the road course I am running 100 octane on my Evo. I am sorry but running 93 octane on the road course is just asking for trouble. On 100 octane you can run stock timing and 11.5:1 AFR w/o knock.
Personally, I tune my 93 octane maps for the occasional WOT run and to learn how to tune. To me the process is more important than the end result.
Old Feb 5, 2007 | 05:54 PM
WrX Kila's Avatar
wow mind blowing!!
Old Feb 5, 2007 | 06:03 PM
A418t81's Avatar
Originally Posted by nj1266
Two things:
Eh, I guess we just have different definitions of "nose dive." When I was running the "smart" xede, I would occasionally get a single audible ping @ WOT and the car would nose-dive for sure. With a KS of 10, which has happened when I'm occasionally trying new things, you can feel it slack up a bit, but it doesn't fall on its face like I've experienced with the Xede screwing things up.
Besides, I wonder how many people have tuned their cars out well in 3rd and then gone out and lugged it through the RPM band in 4th and watched what the ECU thinks of it
Old Feb 5, 2007 | 06:17 PM
Mellon Racing's Avatar
I tuned the car for 0-3 counts it rarely goes higher anymore, now I can beat on the car and not worry about it even when hot lapping it.
Old Aug 29, 2010 | 10:37 AM
BrdgstneEngr's Avatar
Stock Evo 9 High Octane Fuel Map
Stock timing/fuel maps...-uijyu.jpg
So i just read my what i thought was stock Rom today. This is clearly not stock right?. Car is completely stock and was so when i recieved it. Where exactly should i go to find stock Rom image?
Thanks,
Jimmy
Old Aug 31, 2010 | 10:45 AM
drifterific's Avatar
http://evoecu.logic.net/wiki/Downloads
The link above has all of the stock roms.
codean
Feb 13, 2016 08:48 PM
zbents
Jan 21, 2013 03:47 AM
EvoOtto
Nov 11, 2010 06:32 AM
SmurfZilla
Oct 25, 2010 08:49 PM
StreakGSX
Jun 7, 2006 12:01 PM
