Power graph of FPEvo Green
Old Feb 16, 2007 | 08:37 PM
Imyurturboluva's Avatar
Originally Posted by chmodlf
I would really like to see a power graph of a IX vs the FPGreen Turbos (before and after on the same car).
That may be coming soon. I'll be tuning a IX this weekend and he is talking about upgrading to a FPGreen in the near future.
Old Feb 16, 2007 | 11:20 PM
RanEvo's Avatar
[QUOTE=4doorbullit;3984902]I made 394 whp with tbe, intake, 280 cams, 24 psi 100 oct, dc manifold, ebay o2. QUOTE]
394! Wow
Old Feb 17, 2007 | 12:50 PM
cij911's Avatar
Originally Posted by Imyurturboluva
When I first installed this turbo, I was running a split duration of HKS 280/264 and made just about the same numbers you see below. The motor could run in the mid 11 AFRs, 23 lbs of boost and was giddy as a girl. Since then, I thought the 264 exhaust was restricting my top-end power, so I unstalled HKS 272/272 cams with cam gears set at -2* respectively. The issue I don't like now is that I have to run her pig fat just to keep her quiet. Don't get me wrong...she hauls *****, but at a higher fuel consumption. At this point, I think I will swap out my cams for the 45th time. I've gotten quite good at it by now! Anyway, here's a look.
Ok the #'s look nice, but the torque curve seems off....Are you logging boost? Based upon how your torque curve drops (looks like a breast) with peak around 5k I am guessing that you are dropping boost considerably (or you have a leak)....
Old Feb 17, 2007 | 10:18 PM
Yep, I log the boost via Zeitronix and there is no boost leak...tested, and fixed including the TB. I can hold 20+ psi for over a minute. Honestly, I don't think my motor likes the 272s with this turbo, so I'm still searching for a 280 intake cam.
EVOTEXAS
92
Jul 21, 2010 09:24 AM
phatman2600
May 14, 2006 06:27 PM
03redtype-s
27
Apr 17, 2006 09:19 PM
eclipse176
18
Aug 20, 2004 01:49 PM
