hitting really high load on stock turbo?
Old Mar 8, 2007 | 02:30 AM
fbikawi's Avatar
i have the same problem as u SLVR
the logs is showing higher load (260) than it should be if checked using RPM & Ignition to look up the load on the original car map
My boost is spiking max 22 psi and then go down to 19 psi.
me also have the K&N induction Kit and a cat-back HKS exhaust with De-cat pipe.
i was suspecting my load calculations and actually find some thing wrong with it.
my injector scaling = 542 (EVO VII JDM)
and latency calculation should be
inj_latency = (-0.1026*battery)+1.9226
after correcting the calculation, load calculation were closer to the correct but still not ok
if the formulas is 100% correct, then the AFR-MAP reading ihas something wrong.
Old Mar 8, 2007 | 03:13 AM
AF-Evo8's Avatar
get you car tuned for the alky then pull some logs, i don't think its good for your car to be running alky without a tune.
Old Mar 8, 2007 | 04:40 AM
C6C6CH3vo's Avatar
Whith alky untuned your probably in the 9:1 A:F, I was. Post that log in a correct format and put car on dyno with WB to stabilize your A:F
Old Mar 8, 2007 | 11:05 AM
Dapper Dan's Avatar
i tuned my afrs to 11.5 and still hitting the same load.......... any suggestions? i might try swapping my friends stock airbox on and see if that makes a difference....
Old Mar 8, 2007 | 08:32 PM
Dapper Dan's Avatar
just wanted to update this thread.....i scaled my maf and now im only hitting 311 load at its max.....so i guess thats much better that 360....
Raceghost
Dec 14, 2016 12:47 PM
4b11slayer
Nov 10, 2016 07:57 PM
stunt2
May 25, 2012 01:46 PM
PlanoEvo
Sep 4, 2011 03:49 PM
Nuked
May 24, 2008 03:42 PM
