Loads?
Old Jul 31, 2011 | 06:24 PM
PlanoEvo's Avatar
Loads?
What loads are people hitting with their 2.3 or 2.0 with non stock turbos? I am hitting 379 and it won't go any higher using LoadMUT2Byte I get 379 for six or seven lines in a row?
Old Aug 1, 2011 | 12:35 PM
gsrboi80's Avatar
I know there is a way in the ECU to mke it read higher load as I'm sure your car is. I'd hunt the ECU flash forum. I remember Mellon mentioning logging over 500 load
Edit. Looked at my data.xml for evoscan and my current ecuflash xml. There is a modifier number in there that has to match in each XML file. I believe 1.5 is 370 max so you can up it from there
Old Sep 3, 2011 | 04:10 PM
PlanoEvo's Avatar
i guess I'm not that good I'm not sure where to find these files?
Old Sep 3, 2011 | 05:31 PM
gsrboi80's Avatar
https://www.evolutionm.net/forums/8015158-post8.html
Maybe this post will help
Old Sep 3, 2011 | 06:58 PM
PlanoEvo's Avatar
yeah a friend helped over the phone but the 1.9 multiplier is maxing out at 380 load and i need higher should I go to 2.0 or more I need it to be able to read up to say 500 and then back it down so i can see where my peak load value is at right now using 1.9 it goes up to 380 and stays there for almost 2K using evoscan using 1 byte load
Old Sep 3, 2011 | 08:52 PM
Spec-Ops1's Avatar
Its not a 1byte scaling factor problem, you are maxing out the load limit...which is 380... also IPW maxes at this as well...
Code:
85590015:
table name="Set to 9 to remove load limit" address="2a49c" type="1D" level="1" scaling="Hex16"/>
table name="Set to 9 to remove IPW limit" address="2a69a" type="1D" level="1" scaling="Hex16"/>
Old Sep 3, 2011 | 09:11 PM
PlanoEvo's Avatar
Code:
85590015:
Awesome thanks!
Old Sep 4, 2011 | 06:26 AM
Spec-Ops1's Avatar
Let me know how that goes...
Old Sep 4, 2011 | 02:24 PM
tscompusa2's Avatar
that goes both ways. you can unlock the load limit and if you dont change 2byte to 1byte Load Factor it will also cap itself. make sure both are done.
max load i seen on my 2.3 was 536 at 42psi or so.. i went higher in boost but i dont log my car all the time so i dont know what it did at 45psi.
rescaling maf can lower this load number also.
Old Sep 4, 2011 | 03:10 PM
Spec-Ops1's Avatar
Thats why I just log 2Byte load...
Old Sep 4, 2011 | 03:14 PM
lan_evo_mr9's Avatar
Code:
85590015:
What's the 'category' for this code?
Old Sep 4, 2011 | 03:15 PM
tscompusa2's Avatar
2byte is not as accurate as 1byte.. 2byte has less resolution then 1byte. when i log 2byte RPM on cars that cap off on 1byte RPM theres a huge difference in resolution when logging them side by side.
Old Sep 4, 2011 | 03:16 PM
tscompusa2's Avatar
copy and paste into your xml file at the bottom then set to 0x0009
Old Sep 4, 2011 | 03:19 PM
PlanoEvo's Avatar
okay I think I got the cut and paste but unsure of the 0x0009? And as far as changing the load factor you mean making sure both multipliers are the same right?
Old Sep 4, 2011 | 03:20 PM
copied/pasted but nothing is showing up in ecuflash....
