Our ECUs can have eight sets of maps...
Old Sep 6, 2007 | 08:00 PM
  #61
Pd1's Avatar
Pd1
Originally Posted by tephra
Yep its a big task - not overly hard but easy to make mistakes so everything needs to be triple checked.
Also every time someone wants a ROM done I have to basically disassemble it to find all the correct memory addresses for things etc etc..
Lots of folks would be very happy with just the IX version 15 map.
Old Sep 6, 2007 | 08:01 PM
  #62
bigric09's Avatar
subscribed
Old Oct 17, 2007 | 08:15 AM
  #63
aalzuhair's Avatar
bump for update
Old Oct 17, 2007 | 11:14 AM
  #64
Jeff_Jeske's Avatar
I would be happy with two switchable maps.
Please make this happen soon.
Old Oct 17, 2007 | 11:18 AM
  #65
l2r99gst's Avatar
Tephra already has switchable maps working.
Eric
Old Oct 17, 2007 | 11:38 AM
  #66
mfr122887's Avatar
Eric
Are there any threads explaining more about this? How are they switched? Car on or off? Thanks
Old Oct 17, 2007 | 11:48 AM
  #67
MR Turco's Avatar
Eric
Do you mean the valet mode because that is just changing the rev limit. Otherwise i missed something.
Old Oct 17, 2007 | 02:39 PM
  #68
l2r99gst's Avatar
I mean realtime switching actual fuel/timing maps, etc. Not valet mode.
I don't think Tephra has released anything here yet,but he has had it working for quite some time now.
Eric
Old Oct 17, 2007 | 05:18 PM
  #69
aalzuhair's Avatar
i've implemented basic map switching (Fuel + timing #2) in my AUDM ROM, but I have ICS so thats the enable/disable thing.
if this feature is much sort after I could port to USDM's with ICS (and just use clutch + TPS) for map choice...
I also had a request to include boost maps in the switching - although thats a lot more work
cheers
dave
Yes he has
Old Oct 17, 2007 | 05:58 PM
  #70
tephra's Avatar
yup i'm getting motivated to do the whole switching thing ie injector scalings/latencies + boost maps + fuel/timing maps
mainly for the E85 guys but I suppose others will find it useful too!
Old Oct 17, 2007 | 07:07 PM
  #71
turboracer's Avatar
What do yo need for motivation?? I'm willing to mail beer to Australia
I'd love to use this as a meth/nitrous fail safe!
Old Oct 17, 2007 | 07:08 PM
  #72
tephra's Avatar
lol - no I just need to time to spend on it thats all..
Old Oct 17, 2007 | 07:09 PM
  #73
mfr122887's Avatar
Would this be possible? How long does it take to switch the maps? Can it be done on the fly?
Old Oct 17, 2007 | 07:15 PM
  #74
tephra's Avatar
well at the moment switching has to be done with the car off, but IGN on... this is easily changed thou - it was more for safety as I didn't want the car switching maps @ 6000RPM - just in case :P
also its a manual button press in my case, not automatic. what did you have in mind?
Old Oct 17, 2007 | 07:19 PM
  #75
mfr122887's Avatar
Would be possible to have the ZT2 or Aquamist DDS-3 trigger the car to a different map if either went into failsafe mode. Even better, if the car was using the stock BCS or GM solenoid it could lower boost pressure as well. I think that this setup would be the ultimate failsafe for meth.
It would also allow the car to be driven at a lower boost pressure with out meth. This would use the 2nd map and then when the meth is turned on, the 1st map automatically turns up the boost and loads the optimized fuel and timing tables. I think this would be an amazing setup with the stock ECU.
