Boost vs. Timing -- Optimal Power?
Old May 21, 2007 | 04:23 PM
  #46
C6C6CH3vo's Avatar
I naturally give it a little more timing where boost goes south after 6500RPM, AFRs stay 12.0 - 12.2
Old May 21, 2007 | 08:03 PM
  #47
Mellon Racing's Avatar
Originally Posted by nj1266
AFAIK, the boost is set FIRST, then the AFR and then the Timing. If you set the boost AFTER the AFR and timing then the boost might change your AFR readings.
I do set the boost first, it has to be set to something but seriously, after I get the afr and timing dialed in for x boost, I increase boost and tweak timing/fuel to keep knock in check if I'm interested in running more.
If you're raising boost and seeing a significantly leaner AFR something is is up with your fuel pressure. Our cars use a 1:1 rising rate fuel pressure regulator meaning as I increase boost 1psi , the fuel pressure rises 1psi as well. Also keep in mind that the stock MAF meters the extra air coming in when you raise boost. This signals the ECU to go into the proper load column and thus fuel setting.
bottom line..with proper tuning and adequate fuel supply you shouldn't be seeing a different AFR when you raise boost.
Old May 21, 2007 | 09:10 PM
  #48
jrsimon27's Avatar
also fuel increases(gets richer) as you see that the coolant tempetures raises.
Old May 31, 2007 | 06:40 PM
  #49
Ph3n1x's Avatar
These are good timing numbers. You are following the MTBT principle. You run mimimum timing for the best torque w/o knock and not 1* more than that. The "Bubba" school of tuning believe that if a little advance is good, then a lot must be better. And the "tooner" starts cramming more timing down the engine's throat. When the ECU starts protesting and pulls timing, the "tooner" gets flustered and starts block tuning, collapsing the high and low octane ignition maps in the hope that this will stop the ECU from pulling timing. When that does not work, the "tooner" starts making excuses blaming the performance parts on the car. When you fix those and the knock continues, he simply gives up, declares the car a knocker and stops tuning.
This actually happened to my friend.
Thats the most entertaining thing i read in awhile, but sadly your right.
Old Jun 1, 2007 | 07:25 PM
  #50
C6C6CH3vo's Avatar
Here's my methanol approach:
AFR 12.0 - 12.5
4* peak load / 19* redline
Set boost to whatever, if the timing/AFR cells are traced accurately (2 byte) then there is at least a 10 psi window of boost adjustment without going out of tune. For instance my AFR and timing is set whether I run 24 psi or 30 psi
Old Jun 1, 2007 | 09:21 PM
  #51
joosdawg's Avatar
my 93 octane
AFR 11.2-11.6
6-7* peak load / 18* redline
Thats what my motor loves, im on 21psi stock VIII turbo and have sat out on roads for hours tuning that in. Its what feels best but as others have said differnt motors like differnt timing/AFR so try a bunch of combos out til you have what feels and performs best for your car
Old Jun 2, 2007 | 09:06 PM
  #52
Master2192's Avatar
AFR has multiple effects that I haven't seen mentioned here yet.
AFR heavily effects Burn Rate inside the cylinder. A Leaner AFR is like adding timing in the sense that the burn will be completed sooner after TDC. The whole purpose of changing AFR and timing is to get Peak Cylinder Pressure at the best torque angle of the crank.
Some areas of the rpm range may benefit from a leaner AFR and low timing, while other may like a richer mixture with more timing. And this will change with cams and boost.
It is important to approach a tune with this mindset and experiment to find out what works best for the car.
Old Jun 2, 2007 | 09:21 PM
  #53
Ph3n1x's Avatar
Originally Posted by joosdawg
my 93 octane
AFR 11.2-11.6
Ur not cammed are u?
Old Jun 2, 2007 | 11:59 PM
  #54
Nuked's Avatar
If this is who I think it is, nice to see ya join us. I will be in touch with you via AIM on this very subject soon!
SQ aka jasper16g
Old Jun 3, 2007 | 01:05 PM
  #55
joosdawg's Avatar
no im not, stock VIII cams
Old Jun 3, 2007 | 03:38 PM
  #56
Ph3n1x's Avatar
put cams in and youl never see timing like that.
Old Jun 3, 2007 | 03:40 PM
  #57
joosdawg's Avatar
heh i know lol great stuff isnt it.
ridenrunwv
Sep 19, 2015 06:42 PM
David Buschur
Sep 6, 2015 09:27 PM
David Buschur
190
Apr 16, 2009 02:07 PM
PeteyTurbo
GSC Motorsports - Charleston, SC
14
Sep 8, 2008 09:13 PM
sccavee
18
Aug 2, 2005 07:21 PM
