Timing advancing, while knock counts rise
Old Mar 23, 2007 | 12:38 PM
tobz's Avatar
My Friend bought a used 03 evo, on its first 3 gear pull I logged with Mitsulogger, we got counts as high a 17. Around 4000 it knocks up to around 12 counts and starts to pull timing, then after 6000 it still shows lots of knock and yet, timing is advancing now. Can anybody explain this. I will be working on this car for the next couple hours. Going to make sure everything looks good with the plugs, fuel injectors, and everything under the hood, then do another pull to see were we are today.
Old Mar 23, 2007 | 12:45 PM
jcsbanks's Avatar
Timing advances with RPM. The knock count effect is superimposed on the timing map. So this makes complete sense with what you're observing.
Old Mar 23, 2007 | 12:51 PM
Mellon Racing's Avatar
post the log please, also, does the high octane map match the low?
Old Mar 23, 2007 | 01:11 PM
l2r99gst's Avatar
Like John said, you'll still get advancing timing with knock. You just won't get to your set timing advance as dictated in the maps.
Your timing will be pulled about 1* for every 3 counts. So if you are getting 17 counts of knock, the ECU is pulling roughly 6 degrees from what you map says in that RPM/load cell.
The timing will still advance, though. The knock retard is just a correction factor due to the knock counts.
Eric
Old Mar 23, 2007 | 03:21 PM
tobz's Avatar
Got it.. Thanks!
BigEvo908
19
Apr 10, 2017 10:16 AM
VRP
May 16, 2015 04:55 PM
blk-majik
23
Aug 16, 2012 04:20 PM
Akron MR
Oct 10, 2010 10:44 PM
coolguycooz
Sep 16, 2007 09:28 PM
