Ecuflash 1.3
Old Apr 8, 2007 | 02:25 AM
  #31
Redline06's Avatar
I kept 129 as well.. but when it came time to use 130 for the first time.. i went and deleted that version.. then i launched 130 and bam.. "unable to connect to vehicle"
I was like WTF..??
What do they mean by two openports at the same time.. cuz i have my mouse plugged in on USB port 1 and the tactrix on 2.. so you guys think its reading my mouse driver instead of my tactrix which is found on 2..?
Old Apr 8, 2007 | 06:27 AM
  #32
mrfred's Avatar
Originally Posted by nj1266
I think I am getting the same error message that you are mrfred. Glad I kept the 1.29a on my lap top so I can revert back to it.
The fact that 1.29a works fine is probably why this issue hasn't been examined more tenaciously.
Old Apr 8, 2007 | 09:14 AM
  #33
MalibuJack's Avatar
I was like WTF..??
If the mouse uses the same driver, then its possible if its the first device detected on the same driver chain.
One thing you should test if you upgraded from an earlier version..
Go into the openecu directory, BIN directory I think, for 1.3, if there is a FTD2xx.dll file in there, or the directory above it.. rename the file to something like FTD2xx.BAD for the time being..
Driver version differences CAN cause problems and I suspect that theres a 1.29a driver installed and its persistant, since it already works fine, then I'd leave the driver in place and remove the conflicting DLL in the new version of OpenECU
Old Apr 9, 2007 | 05:24 PM
  #34
tirbolag9's Avatar
I had 1.29, but on a different laptop. i just recently installed 1.3 on a different laptop and could not connect to the ecu. ecuflash was detecting my cable and all the associated drivers were in place.
then i uninstalled 1.3 and installed 1.29 and now i can read my ecu.
i've also done the install/uninstall with 1.3 and still get "unable to connect to vehicle interface."
i will try the directory i saw earlier in this thread and see if that works...that's if i can find that directory coz i'm not that computer literate
Old May 26, 2007 | 02:33 AM
  #35
Cloud's Avatar
solved. thanks.
Old May 30, 2007 | 10:42 AM
  #36
Tuned by LIM's Avatar
Question
I had problem with ver 1.3 same many thread above
ECUFlash recognizes the Tactrix cable being inserted/removed in the lower right corner.
But still get the message " unable to connect to vehicle interface. "
So I reverted back to 1.29a and it worked.
Originally Posted by Cloud
solved. thanks.
How to solved this problem?
Old May 31, 2007 | 02:10 PM
  #37
Mojo Rising's Avatar
I have never had any version at all installed and I get the " unable to connect to vehicle interface. " issue. If anyone has ver 1.29 , can you email it to me, please?
EDIT: nevermind @ dontemailme.com
Oh yeah, how do I get rid of the 1.3 drivers?
EDIT: vehicle in question is a 06 IX MR
Old May 31, 2007 | 02:27 PM
  #38
OK, I just rebooted and retried to read. Everything seems to work properly, now.
This, " unable to connect to vehicle interface. " problem only seems to affect Evo IXs. hmm.
Old Oct 6, 2007 | 12:36 AM
  #39
gudmundur's Avatar
Was anyone ever able to resolve the "unable to connect to vehicle interface" issue ?
CaseyK13
Oct 19, 2016 07:00 AM
bigben
Feb 26, 2012 06:42 PM
evohead1
10
Oct 26, 2011 09:01 PM
EvOSean06
May 26, 2011 11:58 PM
cij911
Aug 12, 2010 11:46 PM
