EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
I will add Boost and EGT support for Zeitronix Zt-2, I have the FULL documentation, I just have never implemented it, should only take me 5minutes to implement.
I am currently setting up a login to a website so that I can provide Beta versions of EvoScan.
Evomad can you also rearrange the log order as far as what is logged. Can you make things that are priority at the top of the log, like rpm, tps, knock, timing, wideband, etc. I tried to do it, but I was not able to and I got an error when trying to rearrange the data.xml file.
N-I-CE! Thanks!
Thanks. Zeitronix has been great in supporting MJlogger and Evoscan in providing the info they need to get this stuff implemented.
The first time I edit the xml file, i made a lot of changes and got error.
then I went though and changed this one by one and got it to work.
fyi, you can't move load, or anything used to calculate load. I couldn't move AFRMAP, load, IPW and a couple others.
I was able to move RPM, TPS, knock, timing and WB at the top, though.
ps. i can upload my xml file that has priority items at the top. think evo4mad will mind?
I had no trouble changing the order of the data logged. I just cut and pasted with Dreamweaver. I was careful to not add/leave any extra spaces or hard returns though. XML is very strict markup, so that might be your problem.
Ill give it a shot, do you guys know if you can move 2byte load. I dont care for calculated load anymore lol, I am just trying to move 2byte load. Also when I move knocksum I get an error.
You can move any you like.. there is no specific order. just leave loadcalc below its dependancies, although there is some cool code in there that will tick the dependencies if you leave them untick like InjPulseWidth is require whe LoadCalc is ticked.
BTW by profession I am a programmer(XML is a daily diet). Not nearly as great and all seeing as evo4mad or malibu, etc. but I am able to earn a few bucks...It is easy to assume that what we do sometimes is easy as pie but...Think end user
it doesn't seem that evo4mad cares about user modifying the xml to rearrange the log order. so, if anyone wants to post their modified xml, please do so to help out computer illiterate people.
thanks.
thanks.
Ok I finally got mine modified using dreamweaver instead of notepad. I guess I had some spaces out of sort somewhere, but this time it worked with no error. Make sure you save it as data.xml
spaces in the file shouldnt matter, I just use notepad.exe
A new website is being built over the last 3 weeks with 100s more features than just a log-in, maybe I am being too ambitious with my new website, time will tell
