EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
What could cause Evoscan to make the Ecu freak out setting DTCs for coolant temp, Crank angle sensor, idle stepper (basically all parameters to be logged) and make the engine misfire/almost stall?
What is confusing me is that last night it was working fine.
Second plug
Pull the white plug when you're not flashing.
Well, the freak-out and stall is due to the port getting reset for one reason or another. This does happen when the PC's serial port is reset for whatever reason. The easiest way to avoid it is to not connect the white (single wire) connection to the white nylon port under the dash.
Second issue is the DTC codes in Evoscan, ignore it, they only work for earlier Evo's and it doesnt work with the USDM 8 or 9.
I've noticed a lot of support questions in this thread...is there a forum somewhere they can be asked? I purchased the software about a week back and am still trying to get it to connect. I manage to get ECUFlash and other dataloggers to connect via the tactrix cable, but so far no luck with evoscan...just keeps timing out.
hmm, I can't get .99 to run right at all now. it worked fine for a day or two, now it seems to be affecting the ecu, as rpm will rise for no reason at a stop light, and idle drops when I hit the log button. none of the logged items move , but they all indicate maximum values.
I'm going to reinstall the program and start from scratch.
hehehe
