EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
Hey Hamish, ya know if you need a support forum, let me know, I can set up a subforum on Aktivematrix so you can support your stuff there and not clutter up threads with this stuff.
I did some logging with .99 last night and it's working great. I picked up a serial to usb cable and was able to log my LM-1 Wb02 as well which is best thing since sliced bread.
I spent a few minutes with the power graph feature and had a few questions about the results. I'm showing ~ 400awhp yet with DLL I'm shown ~ 300awhp which is more realistic. Also in Evoscan it shows my car 05 EVO at ~ 3000lbs and I was thinking it was more like 3250 which isn't an option and if it were that 400awhp would be even higher.
also the entire tools and help sections are grayed out and do not respond to clicks.
otherwise it's working great, I'm really glad it has the auto reconnect feature, that's saving me quite of bit of headaches since .97 often took multiple attempts to connect to my car.
I'm just wondering if these are known issues or if I'm doing something wrong.
i got it and was using it yesterday at a drag event to monitor the car. It worked great including the Zeitronix wideband support. The data log file also open well in Office 97 Excel as well. It helped me identified some knocks to correct them. The combination of EvoScan and EcuFlash is awsome.
I hope there'll be boost and maybe egt logging support (at least from Zeitronix) in the future release. Thank Hamish.
If you're familiar with the Data.xml file for EvoScan you can change the order of the items in the Data.xml file and this will change the order that they're listed in the logging screen and probably also the resulting log file (I'll have to verify this).
Since you have an LM-1, why not use Logworks to log it all for you? I think that Evoscan is a great logger, but Logworks is more powerful and has way more features than Evoscan.
i finaly got my .99 to log but it seems to log very slowly when the box's on the right are yellow its logging very slow. when there green its logging very fast. why is that. is there a setting i need to set to make it log corectly. my .97 log'd faster then this. i dont get it
