EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
Old Apr 2, 2007 | 10:11 PM
  #61
SLO-EVO's Avatar
mods thanks for deleting my pic... i posted the wrong one and didnt even realize it... so thanks for helping me out and taking it down
Old Apr 3, 2007 | 12:56 PM
  #62
C6C6CH3vo's Avatar
Finally got to use the 0.99 (been busy watching Indy racing at St Peters) - nice EvoScan upgrade - thanks Hamish!
My TQ/HP seems to more closely correspond to readings at the wheel, is that correct?
Old Apr 3, 2007 | 02:39 PM
  #63
Mellon Racing's Avatar
Originally Posted by nj1266
Since you have an LM-1, why not use Logworks to log it all for you? I think that Evoscan is a great logger, but Logworks is more powerful and has way more features than Evoscan.
I didn't know logworks would log data from the stock ecu without an aux box or rpm converter...
Old Apr 3, 2007 | 02:43 PM
  #64
I setup a few alarms and they never make an audible alert. I can manually play the sound files from withing the program but when my threshold is crossed nothing happends. I verified that the alarm is enabled etc.. I created a few more alarms for other sensors and still no luck. I thought maybe the "warning" sound file was too long but a simple "ding" failed as well.
is anyone having luck with that feature?
Old Apr 3, 2007 | 03:31 PM
  #65
kreionic's Avatar
Every alarm I set it goes off it I hit it. I use the one that "warning" Its a chicks voice and it seems to be the loudest of them.
Old Apr 3, 2007 | 04:41 PM
  #66
TTP Engineering's Avatar
This is an Evoscan thread. How about you make your own thread about your feelings on other loggers.
Evoscan 0.99 is great. Thanks Hamish.
Has anyone tried using gauge templates from 0.97 in 0.99? I have not been able to get that to work yet.
Old Apr 3, 2007 | 07:05 PM
  #67
kmcconn9's Avatar
I am still trying to get the power graph to work/calculate power and tq...any ideas? I did a third gear pull, loaded the log, went to power graph and it shows the whp and tq values/colors in the key, but nothing in the graph, also no numeric values for power or tq on the left side column. I must be doing something wrong.
Old Apr 3, 2007 | 08:07 PM
  #68
nj1266's Avatar
All you need to get Logworks to work with the Tactrix cable is to log your AFR using an LM-1/LC-1. Give the Logworks Tactric cable plug-in a try and you will see how good Logworks is at logging
Old Apr 3, 2007 | 08:25 PM
  #69
LpBevoEvo's Avatar
/ Wrong thread
Old Apr 3, 2007 | 09:19 PM
  #70
ant_turbo's Avatar
How do we use the power graph OnRoad Dyno Graphing feature?? A lil walkthough...
THANKS,,,,,,,
Old Apr 3, 2007 | 09:52 PM
  #71
C6C6CH3vo's Avatar
I enjoy using both LW and evoscan (not at same time of course).
You can synergetically combine the results from both programs to really target and dial your A:F map and get results this way for sure
Old Apr 4, 2007 | 04:55 AM
  #72
kmcconn9's Avatar
THANKS,,,,,,,
I would like to knowe as well as I cant figure it out for some reason...Maybe there is a acceleration mode or something
Old Apr 4, 2007 | 07:49 AM
  #73
evo4mad's Avatar
Email your log file to evoscan at limitless.co.nz and I'll take a look at why the power graphs dont plot for your log file.
Old Apr 4, 2007 | 10:05 AM
  #74
mchuang's Avatar
Yea it is good at logging if your using the rpm converter for rpm like you are. I do not have that item, so when I log rpm it is about 400 rpm off while evoscan is on the money.
Old Apr 4, 2007 | 10:12 AM
  #75
nj1266's Avatar
Very interesting, I hope jjf sees this and chimes in.
