EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
Subscribe
Apr 10, 2007 | 02:15 AM
  #121
Is anyone able to get the boost logging to work? I suspect there is a bug as Mitsulogger v1.6 works fine...And my Zeitronix is working fine....
Reply 0
Apr 10, 2007 | 04:36 AM
  #122
Quote: Is anyone able to get the boost logging to work? I suspect there is a bug as Mitsulogger v1.6 works fine...And my Zeitronix is working fine....
My Innovate LC-1 works fine. Are you sure that you have the correct port selected and is your usb to serial driver working correctly--if you need this. My gps driver conflicts with the usb to serial cable that I use.
Reply 0
Apr 10, 2007 | 04:45 AM
  #123
Quote: My Innovate LC-1 works fine. Are you sure that you have the correct port selected and is your usb to serial driver working correctly--if you need this. My gps driver conflicts with the usb to serial cable that I use.
Yes...Evoscan v.99 is capturing my AFRs fine....and Mitsulogger v1.6 is working fine for both boost and AFRs....So my guess is there is a ZT2 boost protocol issue...
Reply 0
Apr 10, 2007 | 06:04 AM
  #124
Quote: Yes...Evoscan v.99 is capturing my AFRs fine....and Mitsulogger v1.6 is working fine for both boost and AFRs....So my guess is there is a ZT2 boost protocol issue...
Oops thought you were addressing the AFRs...Ask TTP if his is working.
Reply 0
Apr 10, 2007 | 09:12 AM
  #125
I thought Evoscan is not set up to capture egt's and boost from zt. It only takes the WB info. So i don't think it a bug, it's probably by design. Or did it work in 0.9 and 0.97? That's why i use mitsulogger most of the time.
Reply 0
Apr 10, 2007 | 01:08 PM
  #126
Quote: I thought Evoscan is not set up to capture egt's and boost from zt. It only takes the WB info. So i don't think it a bug, it's probably by design. Or did it work in 0.9 and 0.97? That's why i use mitsulogger most of the time.
+1
EVOscan cant get all the info from the ZT2, only AFR.
Reply 0
Apr 10, 2007 | 06:52 PM
  #127
I keep getting a ftd2xx.dll file error.. Any help?
Reply 0
Apr 10, 2007 | 08:59 PM
  #128
when you have the cable plugged into your car, is the "gravel, tarmac, snow" lights suppose to blink??
What specifically is that extra white plug next to the OBDII port used for?
Reply 0
Apr 10, 2007 | 09:26 PM
  #129
Quote: when you have the cable plugged into your car, is the "gravel, tarmac, snow" lights suppose to blink??
Um no? Usually when all three lights blink or are lit up, that means the ACD system needs to be serviced.
The white plug is for flashing/reading the ECU.
Reply 0
Apr 10, 2007 | 09:34 PM
  #130
It only blinks when im not moving, but once I start moving it stops blinking and becomes normal
So I dont need to plug in the white plug if I just want to log?
Reply 0
Apr 10, 2007 | 11:22 PM
  #131
hey so i havent stayed updated lately but i saw that .99 can log 2 byte load, is that real load that the computer sees, or is it still a calculation?
also how do you set up 2 byte load capabilities?
Reply 0
Apr 11, 2007 | 09:36 AM
  #132
Does the map tracing work or how do you get it to work?
Reply 0
Apr 11, 2007 | 09:45 AM
  #133
Quote: hey so i havent stayed updated lately but i saw that .99 can log 2 byte load, is that real load that the computer sees, or is it still a calculation?
https://www.evolutionm.net/forums/sh...d.php?t=261465
Reply 0
Apr 11, 2007 | 09:30 PM
  #134
Quote: I keep getting a ftd2xx.dll file error.. Any help?
go to google, search that file, and then download it...
try typing this in google search engine: download ftd2xx.dl
thats what i did... also, if that doesnt work, try downloading ECUflash...
that should solve your problems
Reply 0
Apr 12, 2007 | 06:52 AM
  #135
Well if Evoscan is not going to capture boost and EGT, then Mitsulogger (which is free) seems like a superior product for my needs...Unfortunate as I had wanted to use the dyno feature...
Reply 0
5  6  7  8  9  10  11  12  13
