EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
Old Apr 2, 2007 | 08:38 AM
  #46
MalibuJack's Avatar
The LC1 has a much higher sample rate than MUT (regardless of who's logger your using) I had to run my Wideband logging in seperate threads than MUT logging just to keep the data in-sync without it overflowing buffers. But sample rates are pretty constant at about 60+ samples per second for MUT, if you find you have really slow rates, or need more information you have to reduce the amount of requests your attempting. Its a twofold thing, the ECU responds to MUT requests when it has time allocated to respond, (timer based) and not whenever its polled.
If you attempt to log 2byte items that arent features enabled or available in your ECU, then you also are waiting for timeouts, which can significantly slow down your polling speed.
Old Apr 2, 2007 | 08:39 AM
  #47
MalibuJack's Avatar
and PLEASE take that image of your serial number down..
Old Apr 2, 2007 | 09:09 AM
  #48
CarFanatic's Avatar
does this work with the Zeitronics zt2? I have the wideband with boost logging.
Old Apr 2, 2007 | 09:44 AM
  #49
malachi's Avatar
how can i get evoscan to my laptop?
Old Apr 2, 2007 | 11:13 AM
  #50
RedV's Avatar
Hmm... let's see...
- Download via the Internet
- Wireless/wired ethernet network
- CD/DVD
- USB thumb drive
- Infrared transfer from another laptop
Old Apr 2, 2007 | 11:44 AM
  #51
EvoRicer's Avatar
I got my Download in the Email but it doesn't show me my Serial Number...
Old Apr 2, 2007 | 01:00 PM
  #52
kreionic's Avatar
deleted
Old Apr 2, 2007 | 01:19 PM
  #53
recompile's Avatar
Might wanna take that screen shot down
Old Apr 2, 2007 | 01:26 PM
  #54
Evo_Jay's Avatar
Originally Posted by G20
i got it and was using it yesterday at a drag event to monitor the car. It worked great including the Zeitronix wideband support. The data log file also open well in Office 97 Excel as well. It helped me identified some knocks to correct them. The combination of EvoScan and EcuFlash is awsome.
I hope there'll be boost and maybe egt logging support (at least from Zeitronix) in the future release. Thank Hamish.
I used to use Excel to view the logs, but in .99, you can view the logs in EVOscan.
Also I think the graphing in .99 is great. I dont even Excel anymore.
Old Apr 2, 2007 | 01:43 PM
  #55
CarFanatic's Avatar
how do you get the zeitronics to interface with the evoscan?
Old Apr 2, 2007 | 01:57 PM
  #56
turbotiger's Avatar
As far as I found out with evoscan after purchasing, only mitsulogger logs boost along with afr on the zeitronics zt-2
Old Apr 2, 2007 | 03:01 PM
  #57
Speedlimit's Avatar
Admin Emeritus
I removed the screen shot containing the serial number.
Old Apr 2, 2007 | 03:06 PM
  #58
CarFanatic's Avatar
Crap so I just needed to get mitsulogger, instead... waisted 25 bucks??
Old Apr 2, 2007 | 08:16 PM
  #59
BlackIX's Avatar
Can't you log boost using Evoscan and a jdm map sensor?
Old Apr 2, 2007 | 09:06 PM
  #60
Evo_Jay's Avatar
yes.
but i believe the guy above has zeitronix and want to log boost from that, which only mitsulogger can do
