OEM Style Gauges for EvoScan .99
Old Apr 7, 2007 | 02:24 PM
TouringBubble's Avatar
Originally Posted by jdmevo8313
I downloaded both templates and the layout but when I load the gauges only the left side would open.
You might have to set them up yourself rather than use the layout provided. I run fairly high resolution on my notebook and that might be the issue.
Old Apr 7, 2007 | 02:48 PM
jdmevo8313's Avatar
Registered User
I messed around with my resolution and I got it to work. thanks
Old Apr 7, 2007 | 03:03 PM
laakness's Avatar
Yeah, you can just load each individual gauge provided and edit/resize them and save your own layout.
Old Apr 7, 2007 | 11:22 PM
codgi's Avatar
I downloaded these today good job
Old Apr 29, 2007 | 08:41 AM
LV///R's Avatar
Forgive my newbiness, but could you give me some instructions:
1) Where do I save the files?
2) How do I get them to work in evoscan?
Any advice/how to's would be much appreciated...
EDIT, i think I got it figured out...Nevermind!
Thanks!
Old Jun 3, 2007 | 12:26 PM
Gauges updated to v.002. Enjoy.
Old Jun 3, 2007 | 01:46 PM
SICK9's Avatar
Thanks!
+1 on the how-to.. step-by-step
plz forgive my ignorance, just got evoscan and still learning how to use it.
BTW: love the guage layout, very nice work..
Old Jun 3, 2007 | 01:52 PM
recompile's Avatar
The Left and Right XML files go into \EvoScan\GaugeTemplates and the Layout file goes into GaugeLayouts
Then from EvoScan, go to Gauges > Load Layout
Old Jun 3, 2007 | 01:56 PM
kreionic's Avatar
keep in mind that you might have to resize them to fit your screen. To do that just go to add/edit gauges. Select the right gauges and set the data accordingly and then hit create widget. Do the same for the left side and then go to gauges on evoscan and save gauges as.
Old Jun 3, 2007 | 02:02 PM
Added some step-by-step instructions to the first post. Hope it answers most of the questions. I should have done it to start with ...
Old Jun 3, 2007 | 07:50 PM
Mike01gsr's Avatar
downloading these now...Thanks alot man!! Can't wait to try them out!!
Old Jun 6, 2007 | 05:58 PM
Thoe99's Avatar
How come some of the gauges don't work when I do a playback? I know I logged those data too, like speed and rpm. My boost also reads 50psi?
Old Jun 6, 2007 | 06:26 PM
kreionic's Avatar
Are you using the JDM map sensor? If not the boost gauge will not work. Did you check to see if they data was assigned to the gauges.
Old Jun 6, 2007 | 06:36 PM
Yup, JDM MAP is required for boost logging. As far as the other gauges, just be sure the values are assigned correctly. Even if they weren't assigned to the gauges you can still assign them after the log and view them during playback.
Which gauges aren't working?
Old Sep 11, 2007 | 08:05 PM
lemmonhead's Avatar
how can you put both left and right side together? I want the speed and rpm showing with the other one at the same time.
