110 octane
Old Apr 5, 2007 | 05:15 PM
llabmik2's Avatar
110 octane
What kinda of timing can i run with 110, how much can i really advance it. Is there a certian percentage per octane point, or is it just trail and error. I beleve that i can also put my AF in about the 11.8 to 12.1 area correct? This is at 22 lbs of boost. With bolt on except cams.
Old Apr 5, 2007 | 06:13 PM
elhalisf's Avatar
psi at around 26-27
timing, 10* on 260 load @ 3k rpm, progressivly going up to 20*
AFR at 12.0
Headstuds, HIGHLY RECOMMENDED
Old Apr 5, 2007 | 11:11 PM
Ralph's Avatar
^what he said. Although I've been higher than 20 degrees in the higher rpms .
Old Apr 6, 2007 | 05:51 AM
AutoXer's Avatar
What about 100 Octane unleaded?
Old Apr 6, 2007 | 09:32 AM
elhalisf's Avatar
AFR to 11.7-11.8
Boost to about 25-26psi
same timing
Old Apr 6, 2007 | 11:04 AM
RazorLab's Avatar
10* at peak 26psi with 100 octane?
Have fun with that.
Old Apr 6, 2007 | 11:45 AM
elhalisf's Avatar
Have fun with that.
I was doing 8* at peak 24psi on 93 pump gas, tunned to 11.6-11.7 AFR. but that was an agreesive tune.
Old Apr 6, 2007 | 12:02 PM
llabmik2's Avatar
well i have a soft spring in my MBC so i cant at this moment go over 22 lbs, the track opens tomorrow so i just figured hell, ill put here on my own special race gas, its about 110-115 no lead. Bump the timing up and lean her out a little more. So i was thinking that i should keep it around 20* up top and about a 12.0 af. That should be safe with 22 lbs and high octane right.
Old Apr 6, 2007 | 12:55 PM
elhalisf's Avatar
well, why dont you use the stock BCS to bump up the boost? do you still have the stock boost lines?
FilthyEvo
Sep 5, 2012 10:40 AM
06mr775
Apr 27, 2010 02:54 PM
RyuEvoIX
23
Nov 8, 2007 07:18 AM
evovin
Apr 14, 2007 07:25 AM
Jeff_Jeske
19
Aug 9, 2006 09:26 PM
