Can someone look at my logs???
Old Apr 10, 2007 | 06:00 PM
rraulston's Avatar
Did my first logs. Finally got the logger working. The AFR is 10.5 from 0-20 psi. Dont bother with the sig. its needs updating.......Thanks in advance for the feedback... Ray
File Type: zip
File Type: zip
Old Apr 10, 2007 | 06:05 PM
kreionic's Avatar
You have some issues between 3500 and 5700 rpms
Old Apr 10, 2007 | 06:08 PM
TeStUdO's Avatar
Just a question....are you getting that load calc with a GT-30r?
Old Apr 10, 2007 | 06:13 PM
Ryu123's Avatar
I'm by no mean an expert but I would suggest dropping your timing a degree or two at peak torque around 3.5K to 3.8K.
Old Apr 10, 2007 | 06:15 PM
VenomEVO8's Avatar
I was just going to say that.. Looks like a timing issue
Old Apr 10, 2007 | 07:05 PM
nothere's Avatar
my mistake. i can see the logs well enough.
Old Apr 10, 2007 | 07:09 PM
kmcconn9's Avatar
a wideband log would definatly help...looks like a fuel and/or timing issue
Old Apr 10, 2007 | 07:26 PM
JohnBradley's Avatar
Just based off the NB voltage its a little rich (for my tastes), but the thing that I cant quite understand is why the MAF clip is still about stock rpm. I realise load calc will be off with the use of different injectors even with the fuel trims being close, but Hz is Hz and I would have thought a bigger turbo would have moved more air lower in the rev range. I think a little more info is needed, but the csv logs are easy enough to read.
Old Apr 10, 2007 | 07:44 PM
rraulston's Avatar
sorry folks, the turbo kit was taken off and a 9 turbo was installed last week. I havnt updated my sig yet. I will do that asap. I just dont know what knock column is th important one.........Fuel is 10.5 from 0 to 20psi. Thanks for the input. Ray
Old Apr 10, 2007 | 07:46 PM
rraulston's Avatar
what columns are you looking that tell you ime having issues????? Ray
Old Apr 10, 2007 | 07:51 PM
Ph3n1x's Avatar
Your pushing your timing way to much throughout the ENTIRE Power band. Your way to aggressive. If you think your knocking now...wait until you go into 4th at WOT. Just highlight all the high load cells from 200-300 from 3500RPM-11000RPM and take everything down 3-4 Degrees.
At that load you are not 20psi.
nj1266's Avatar
The important column is the Knock Sum column. From what I can tell you have too much timing @ peak torque/boost. Your timing is set ~8* @ 3500 rpm and that is just too much. Your getting 6 counts of knock and that is pulling your timing 2*
Old Apr 10, 2007 | 07:52 PM
Ph3n1x's Avatar
Post you AFR's in a 4th gear log at WOT.
Old Apr 10, 2007 | 07:56 PM
fastrob691's Avatar
you went to a IX turbo, why, this is Rob white evo, we were out at trackday in Deming couple months ago together?
Old Apr 10, 2007 | 07:59 PM
sekula's Avatar
wow...def. decrease the timing unless you want to decrease the boost...which i doubt you want to...
