2.4L & 3065 finished - need help with base map
Old Apr 11, 2007 | 01:47 PM
MrEvo2U's Avatar
Finally got the car together with 2.4L and 3065. Has all supporting mods (fmic, 880's, 264/272, COP,etc.) I have been researching A LOT and trying to tune the car myself with Ecuflash/Evoscan/Zeitronix. My problem is that I am SOOO far away from the base map that I need some help. (I have already fixed boost cut, changed timing maps, fuel maps, rescaled open loop load and throttle, etc.) My car gets into high load cells very early and without any real boost. Also having a problem getting into open loop soon enough. I am happy to pay for a map/tuning help. Am I better off to call Dynoflash or Jestr and see if they have a map that is close?
Old Apr 11, 2007 | 01:58 PM
Ph3n1x's Avatar
You are definitely better off calling Jestr tuning or TTP. Have them establish a good conservative tune and then tune yourself from thjere.
Old Apr 11, 2007 | 03:14 PM
TTP Engineering's Avatar
You are not tuning correctly. The last thing you should be worried about is ignition timing. The first thing is injector deadtime and scaling.
I would not be attempting what you are trying to do with knowing what you have posted thus far.
Old Apr 11, 2007 | 05:13 PM
MrEvo2U's Avatar
I realize that I'm a little over my head - and I'm being VERY conservative with tuning (less than 10lbs boost and under 140 load so far). I copied another person's ignition map (which was way more conservative than stock) and scaled the 880's to 665. o2 feedback is within 20% (not great, I know). I used AEM values for the latency taken from another thread here. It is taking forever to tune which is why I was asking for a base map from a reputable tuner. I built the entire car myself (RRE built the 2.4L), so I'm not a total newbie (maybe 50%?)
Old Apr 11, 2007 | 05:16 PM
GHEvo8's Avatar
i cant wait to see this when its finished
Old Apr 11, 2007 | 07:13 PM
cpoevo's Avatar
If RRE built the engine you must not be too far from them. Why not have Dr. Gray tune your car and it will definitely be tuned by one of the best in SoCal.
Old Apr 11, 2007 | 09:21 PM
MrEvo2U's Avatar
I'm in Nor CA so RRE is about a 6 hour drive. Vishnu used to tune it back when it was 2.0L w/XEDE. When you start having parts from Works, Vishnu, Buschur, RRE, etc (they ALL have some parts that are excellent) you end up tuning it yourself or having someone like Dynoflash or Jestr tune it.
Old Apr 11, 2007 | 11:20 PM
RazorLab's Avatar
There are tuners in they bay area you know...
Old Apr 12, 2007 | 08:01 AM
MrEvo2U's Avatar
razorlab - can you PM me some suggestions. My car has been to most of the Bay Area tuners for various parts. Which ones are good and know Ecuflash well?
Thanks for the constructive post.
Old Apr 12, 2007 | 08:57 AM
nj1266's Avatar
Razorlab is a tuner. He tunes @ GST. Give him a pm and have him tune your car. He has been very helpful to me. He helped me create a boost map for my ECU and did it on his own dime. I like the guy a lot. I hope I meet him one day and buy him He loves beer
Old Apr 14, 2007 | 12:37 AM
cloudy's Avatar
Wow I thought I was the only one with a 2.4/3065 combo. Or even a stroked evo w/ 3065 for that matter.
Well I am changing my turbo now anyway, so looks like you are back to the only one :P.
Old Apr 14, 2007 | 12:48 AM
Wazvette's Avatar
a 2.3 + 3065 here....and I know a couple on evoM with stroked motor and a 3065...not a 2.4 though...my combo is fairly common I would say.
Old Apr 14, 2007 | 10:16 AM
MrEvo2U's Avatar
how is the boost curve? Are you changing to go bigger or for other reasons?
Green_Bandit
Lancer Engine Management / Tuning Forums
Jun 19, 2013 04:39 PM
stunt2
Mar 19, 2011 05:04 PM
Jim in Tucson
Nov 21, 2010 09:29 AM
jcsbanks
Sep 11, 2009 04:12 PM
pltek
Mar 17, 2009 07:33 AM
