Near Perfect Tune....
After logging, then tuning then logging, then tuning some more x50, I think i've got to where the car runs hard.
3rd Gear Pull - FULL LOGS IN POST 12
Mods:
Stock Block/Head/Turbo
Full 3 Inch Exhaust
Ported Manifold
Ignition Amplified
280 Cams and Cam gears
Electronic Boost Controller
Fuel Pump
Intake
Aftermarket Radiator
FMIC and LICP
o2 Housing
Dual Catch Can
Zietronix Wideband
N.B-Boost is 22PSI @ 3500RPM, My Peak TQ is 4500RPM which is where the 23Psi comes in just for a split second
and tapers to 20PSI at 7k.
4th Gear sees 11.5:1 AFR's from 3600RPM-7K consistently!
Car Pulls hard throughout the entire powerband, unlike the typical tq curve that peaks and then falls off.
Mods:
Full 3 Inch Exhaust
Ported Manifold
Ignition Amplified
Fuel Pump
Intake
FMIC and LICP
o2 Housing
Dual Catch Can
Zietronix Wideband
and tapers to 20PSI at 7k. 4th Gear sees 11.5:1 AFR's from 3600RPM-7K consistently!
Is there any way to adjust the AFR resolution with that, it's quite difficult to tell the difference between lean and rich just from a screenshot?
Can you post the full log with time seconds?
Thanks
Thanks
Nice tune. You might look at your high fuel trim. BTW the High and low fuel trims are reversed in v.99. I posted that this is off but who knows if evo4mad read it. Strange that the xml file would be wrong for only version .99
2005 = Evo 8
errr....fast
I log the Wideband and boost with the Zietronix Datalogger. If you have the software I can upload that log.
