logging boost???
Old May 2, 2007 | 09:13 PM
vwjeff's Avatar
logging boost???
Ok guys I did search and I just cant find my answer to my question
I installed some different gauges a few weeks ago
https://www.evolutionm.net/forums/sh...stewart+warner
My problem is that my new SW is reading 3 to 4 psi lower than my AM was.
So I hook up my cable and go for a drive. Here is what I am getting.
I am looking at the MAP senser on the log and it is showing in a 3rd gear pull at what was 23 psi on the AM and now only 19 on the SW gauge... 329.498 KPa... WTF
When I convert this it was something like 48psi, and we know that aint right
Next up I checked the Barometer but it was staying around 100 KPa, so I know that aint it either.
So what gives here am I looking at the wrong things, do I need to divide something somewhere, any ideas would be GREATLY appericated
I gotta get this figured out by this weekend, track day is the 7th (monday).
Old May 2, 2007 | 09:27 PM
Ralph's Avatar
You're looking at the stock MAP sensor values? Or are you using the JDM IX map sensor? My JDM IX Map is 100% accurate and matching my Stewart Warner Gauge.
My AutoMeter was off by 3-4 PSI.
Old May 2, 2007 | 09:42 PM
vwjeff's Avatar
Yes it is the stock MAP, is there a difference between the 2
Old May 2, 2007 | 09:46 PM
Ralph's Avatar
https://www.evolutionm.net/forums/sh...52#post4074452
Read that post
I believe the stock MAP only reads up to 0psi or 1-2psi.. something like that.
The JDM IX Map sensor is a 3 Bar Map. Should be 100% accurate..
Old May 3, 2007 | 12:49 PM
vwjeff's Avatar
Thanks Ralph
Bump so any more ideas
Old May 3, 2007 | 04:41 PM
chrisw's Avatar
not all boost gauges are created equal. I am assuming these are both mechanical gauges right?
Old May 3, 2007 | 08:44 PM
vwjeff's Avatar
yeah, they are machanical.
I understand not all are equal but da*m 4 psi
nonschlont
Aug 26, 2011 12:08 PM
vwjeff
11
Apr 24, 2007 01:46 PM
Pr3z
11
Mar 15, 2007 09:09 AM
sochize
Sep 14, 2006 08:44 PM
WEVO
May 16, 2005 04:05 PM
