Knock Gauge and Alarm
Old Jul 29, 2007 | 01:09 AM
  #46
tephra's Avatar
sorry guys, Ive been trying to implement the other mods as well, release one big patch if you will! BUT I can't find the MUT codes for any other inputs (A/C or demister...)
will keep you posted!
Old Jul 29, 2007 | 06:09 AM
  #47
mrfred's Avatar
I thought that you had passed over the A/C switch. Is there something in particular that you're trying to find?
Old Jul 29, 2007 | 04:47 PM
  #48
tephra's Avatar
mmm the A/C MUT request only works when the car is running, therefor im thinking its a compressor = on/off flag..
I just need a switch that I can use while the car is off (ive used the clutch + TPS) for other things...
Old Jul 29, 2007 | 08:09 PM
  #49
C6C6CH3vo's Avatar
How possible would it be to set a patch tha would keep the IC spray relay from being energized no matter what the current settings are, if knock sum reaches 8 counts?
The auto switch must still be functional when < 8 counts because I currently have the IC relay controlling my stock DV going in stop leak mode at 2.75 volts TPS and definately want to keep it functionable.
This would be a decent failsafe for me since the car only boosts to 19 psi with the IC auto switch off, but holds more solid than any other valve I used (stop leak mode) for over 30 psi
Old Jul 29, 2007 | 08:20 PM
  #50
tephra's Avatar
sorry C6 I didn't understand what you said
I am going to add a feature which automatically turns on water spray (ICS not meth injection) when knock appears (>1 knock over 150load say...)
Old Jul 29, 2007 | 08:54 PM
  #51
C6C6CH3vo's Avatar
I'm looking for the possibility to do the opposite, deenergize the IC spray relay at a set knock point e.g. > 5 counts. I currently have the IC relay energizing at 2.8volts TPS.
Currently whenever I'm at 2.8 TPS it energizes a solenoid that makes my DV collaps and hold shut without leaking (it's bubba engineered), if I can disable this only durring knock then that would be the ultimate failsafe for me because it would only boost 20 psi
Old Jul 29, 2007 | 09:04 PM
  #52
tephra's Avatar
DV?
ok so when you over a knock threshold you want to disable the IC relay... not a problem - it would have to be a custom jobbie for you thou, as Im not sure how many other people have your specific setup hehe
Old Jul 29, 2007 | 09:15 PM
  #53
C6C6CH3vo's Avatar
Yes, DV.
It's a painful process explaining how it works but yes, if the IC relay is deenergized at a set knock point then motor won't boost 20 psi (turbo will spin like mad but those are cheaper )
PMdya
Old Jul 29, 2007 | 09:25 PM
  #54
tephra's Avatar
hehe no I meant whats a DV?
Old Jul 29, 2007 | 09:39 PM
  #55
XK120's Avatar
I'm very interested in this...how is it coming alon tephra?
Old Jul 29, 2007 | 09:47 PM
  #56
Kevindanger's Avatar
+1
Old Jul 30, 2007 | 02:07 PM
  #57
Evology's Avatar
very interested as well, but will this work with a JDM evo VII??
Old Jul 30, 2007 | 05:02 PM
  #58
Pd1's Avatar
Pd1
I'm just interested in the simple CEL flashing when the car knocks a designated amount or more.
Old Jul 30, 2007 | 05:51 PM
  #59
tephra's Avatar
mmm seems a lot of people are!
I *might* just release a cel flash rom, what ROMID you got pd1?
Evo7 : will need to back port it... might take a while given i'm still working on other 9 ROMS!
Old Jul 30, 2007 | 07:10 PM
  #60
C6C6CH3vo's Avatar
Ooops Diverter Valve. I try to avoid calling the diverter valve by BOV. BOV's are pressure relief or venting valves, diverter or bypass valves are what evo's use.
Just a way with words you know, kinda like the organic equivalent to regulator valves are sphincters
BTW, It may be awhile till the unmodified ROM get's to you but I did find a 96420008 which I think is the same as a 96420007
