Evo anti-lag ECU disassembly
Old Mar 21, 2008 | 02:10 PM
  #286
taavisev's Avatar
can someone look at the ROM 88840017?
because i´m not that good in IDA yet...
thanx
Old Mar 21, 2008 | 02:34 PM
  #287
BarryC's Avatar
Originally Posted by JohnBradley
Yes there is a table that hasnt been defined yet. BarryC found it for his VIII, but I dont think anyone has started looking for the IX as of yet. I think he found that the value could only be increased on his an additional -5*...from -5 to -10. It may well be maxxed as far what it will allow.
yep John this table will allow ya set the Max ammount of timing retard and that is -10 deg,
this is for the evo 7 and 8
<table name="Timing Retard Limit" category="Timing" address="173f" type="1D" level="1" scaling="uint8"/>
evo 9
<table name="Timing Retard Limit" category="Timing" address="133f" type="1D" level="1" scaling="uint8"/>
add these tables to evo 7 base or evo 9 base and set the limit to 255
it will allow -10 deg for those that cant get the timing down that low,
makes a big difference to the pops and bangs.
Old Mar 21, 2008 | 03:07 PM
  #288
taavisev's Avatar
right now i get -10 if i log it. but if i change this valua 203 to 255 what i get then?
sorry dont have my car to test it
Old Mar 21, 2008 | 04:46 PM
  #289
JohnBradley's Avatar
203=10
255/203=1.256
1.256x10 would seem to indicate you could max out at -13 if it runs linear.
Old Mar 21, 2008 | 11:50 PM
  #290
al\lupo's Avatar
thanx
88840017 uses same addresses of 16; tables are not referenced too.
Old Mar 22, 2008 | 12:42 AM
  #291
al\lupo's Avatar
203=10
255/203=1.256
No, 203 is the decimal view for hex 0xCB, that is a negative number in two's complement. So 0xCB means -53. In the code this value seems to be manipulated adding 0x2A (42), so the minimum timing value should be -11 also if we are logging -10 as lower value. The timing calc routine is complex, moreover this limit *seems* to be in some kind of knock reaction... could someone with more experience in the timing routine check, please?
Old Mar 22, 2008 | 05:14 AM
  #292
taavisev's Avatar
another question...
is it possible to hold throttle open like 25% with ecu?
then we need rich the AFR and timingi -35 to 40 thats hard anti lag thats how n class evost working now!
is that possible.
i know that TPS is physically connected but maybe idle engine can to the trick!
then we dont need hardware to do it!
Old Mar 22, 2008 | 11:32 AM
  #293
Thank you for the correction...I didnt think I understood it 100%...now I do
Old Mar 23, 2008 | 12:15 PM
  #294
mrfred's Avatar
Have you guys found anti-lag tables in the 88590015 ROM?
Old Mar 23, 2008 | 12:55 PM
  #295
Not yet...other than the ones that JCS highlighted in the beginning..I havent had much time to look into it recently but I am trying to get the project back on the road.
Old Mar 23, 2008 | 12:57 PM
  #296
agron25's Avatar
Have you guys found anti-lag tables in the evo IX ID88840016 ?
Old Mar 23, 2008 | 05:46 PM
  #297
kkarim's Avatar
agron25: i have them for the 88840017 rom (i have xml and hex) if you're interested.
i'm sure they are pretty much the same as the 016 version.
pm me your email if you want them.
Old Mar 24, 2008 | 12:55 AM
  #298
al\lupo's Avatar
I have posted them some pages ago in this thread.
Old Mar 24, 2008 | 07:06 AM
  #299
Dan EvoIV's Avatar
i have jdm evo 8 MR rom+ def with antilag enabled and working if it helps.
Old Mar 24, 2008 | 12:08 PM
  #300
NineWorks's Avatar
I think this can be of some interest... can you post it here ?
Cheers
