Evo anti-lag ECU disassembly
Old Jul 4, 2008 | 05:09 PM
  #346
dolphin888's Avatar
Sorry for posting in an old thread. I just wanna know if anybody had success in making USDM Evo VIII working ALS
I still believe that it is possible to retrofit SAS in USDM Evo...
Old Oct 10, 2008 | 02:16 PM
  #347
laramie_05MR's Avatar
Is anyone still working on implementing anti-lag?
Old Oct 10, 2008 | 02:30 PM
  #348
tnt1106's Avatar
I found a link for the code, here it is:
<antilag code>
Old Dec 12, 2008 | 03:29 AM
  #349
eTiLiKo's Avatar
Have anyone the impression that the "ALS ignition advance adder" table doesn't work?
Old Dec 13, 2008 | 07:20 PM
  #350
Murf's Avatar
Originally Posted by 555R
if it comes factory then its probably mildly activated
so i dont think there would be much in the form of damage
i have thought of trying to find a complete setup and adding it to my car but you can never find a complete factory secondary air injection/antilag anywhere
interesting find though
I have 2 setups sitting around, minus the manifold banjo bolts that is. I have the piping the valve turbo, and manifold
Old Dec 14, 2008 | 02:55 PM
  #351
I have most of the parts too.
Old Dec 23, 2008 | 06:22 PM
  #352
j3llyh34d's Avatar
Uk 03 viii fq-300
Hello
I'm a late entrant into this thread, I have taken the time to read it from the top....
I already have the "software" ALS on the stationary rev limit but would like to use the "proper" SAS system. Given my car is UK/JDM spec and I already have SAS - it should be as simple as...
1. Drill out the 2 Banjo bolts to ~5.5mm diameter
2. Verify the table definitions in my XML (done look okay)
3. Add a little air in the tables to increase effect
Can anyone advise? or has anyone succeeded with a similar car?
Thanks,
j3llyh34d
Old Dec 24, 2008 | 08:16 AM
  #353
grayw's Avatar
You should not need to drill out the banjo bolts on the VIII.
I posted some basic ALS settings here.
Originally Posted by j3llyh34d
Hello
Thanks,
j3llyh34d
Old Dec 24, 2008 | 12:05 PM
  #354
j3llyh34d's Avatar
I shall experiment and report back! Thanks grayw
Old Mar 9, 2009 | 12:58 PM
  #355
javevo's Avatar
hello, we know something of the original ecu with als?
Old Mar 9, 2009 | 01:01 PM
  #356
javevo's Avatar
Here a video I got of what reading this, thanks http://www.youtube.com/watch?v=DJWwjNo1yg4
Old Apr 1, 2009 | 01:26 AM
  #357
Danieln's Avatar
Originally Posted by agron25
ok
thank
I find
time 0.0 is good
rmp
1750/2000/2500/3000/3500/4000/4500/5000/5500
is good or no?
Hi Lupo,
Seems that until now you are veteran here so you know more than others about ecu.
Did you try this definition??Is working on rdm cars?
I have 88840017 ROM id.
Do you have definition file for 88840017?Is 88840016 the same for 1,7?
Thanks
Old Apr 1, 2009 | 01:33 AM
  #358
Danieln's Avatar
Originally Posted by ICEounet
merci franck tu fais avancer les choses toi
Hi,
Can you please give me the deffinition file also?
For me if I introduce the xml files at als injection time I have xxx
Thanks
Old Apr 1, 2009 | 01:43 AM
  #359
Danieln's Avatar
Originally Posted by kkarim
agron25: i have them for the 88840017 rom (i have xml and hex) if you're interested.
i'm sure they are pretty much the same as the 016 version.
pm me your email if you want them.
Hi mate,
Can you please send me also definitions for 88840017 Rom versions?
Can I send you PM?How can i get it from you?
Is this working in 88840017?
Thanks......
Old May 3, 2009 | 07:10 AM
  #360
FX11's Avatar
so anyone get this for US vehicles?
