Evo anti-lag ECU disassembly
Old Jul 11, 2009 | 11:04 PM
  #391
spdracr's Avatar
Originally Posted by mrfred
Probably, but to know for sure, I'd have to see the factory service manual for the donor Evo to see what solenoids are being operated by which of the PWM outputs on the donor Evo ECU.
so in other words it would be a pita
Old Jul 12, 2009 | 05:58 AM
  #392
mrfred's Avatar
Not really. If I had the factory service manual with the ECU wiring diagram, I could figure it out within an hour.
Old Jul 12, 2009 | 09:14 AM
  #393
spdracr's Avatar
i was just reading about a guy with a usdm 8 out here that has the antilag semi working still tuning and stuff. but he ran a evo 7 rom in his stock ecu i believe would this work and how can i get evo 7 rom with the right definitions so i can do this
Old Jul 25, 2009 | 08:03 AM
  #394
Oettinger's Avatar
Is necesary install SAS Valve for ALS? In my EVO VIII European, this valve is not installed
Is exact this image my engine, without SAS Valve and any holes for two banjo.
Old Jul 25, 2009 | 12:32 PM
  #395
Biggy VIII's Avatar
You can put -15 in 0-30load\4-7Krpm and change your ignition retard limit to 255 (stock is 203), and enjoy the same bang-bangs.
"works" the same way as on the video a couple of posts above.
But i cant really tell you if it helps spool because i'm auto-x-ing still on stock 8 turbo. ))))))))
Anyway its looks and sounds impressive )))))))))
Old Jul 25, 2009 | 01:06 PM
  #396
Oettinger's Avatar
But my turbo is negative presion, -550mg, not positive, without SAS valve no bang
Old Jul 25, 2009 | 03:54 PM
  #397
Biggy VIII's Avatar
I bet nobody really gets positive pressure using SAS or not. It probably theoretically just helps a little bit to spool quicker after you released and pushed the throttle again.
I also know a couple of evos (2005) that do not bang at all, whatever timing you use in lift-off part of the map.
Actualy if you want some positive pressure on lift-off, you have to use SAS valve and use it instead of your stock bov valve. Than you have to put some more fuel and some real negative timing in all 0-100load\2,5-7Krpm area to make it function like real ALS. But that will put some reall stress to ex.valves, ex.manifold, turbo, and your wallet as a result... Cops and neighbours will experience some stress too if you use it on the street.))))
Old Jul 25, 2009 | 08:41 PM
  #398
Oettinger's Avatar
Is for circuit. Only create sound of bang but not charge to 0.0b turbo in idle. I need create a real-bang, not simulated bang (only sound), my pression is -550mg in idle, i need 0.0 or positive. My evo is 2005 GSR without sas valve or egr tubes. I need?
Thanks!
Old Jul 26, 2009 | 02:55 AM
  #399
Biggy VIII's Avatar
Thanks!
yes you do need SAS hardware or any other device that will pass air dirrectly to ex.manifold, - so you will be able to make a combustion in the ex.manifold before the turbo. You also have to retard ignition to -30-45 degrees, but stock ecu is able to retard only to -10. Thats enough for a bang sound, but not enough for ALS to fully function.
Old Jul 30, 2009 | 04:46 AM
  #400
Oettinger's Avatar
With this mod in the ecu, you can retarding more -10º. Only put -30º and obtain ALS in my evo without SAS hardware or any other device???
https://www.evolutionm.net/forums/ec...ard-limit.html
Old Jul 30, 2009 | 03:24 PM
  #401
Biggy VIII's Avatar
not more than -10 is available. it is still not enough.
you need air and fuel to be in exhaust manifold and about -30 -40 degrees of timing.
Old Jul 30, 2009 | 06:41 PM
  #402
Oettinger's Avatar
Ok! More thanks Biggy!
Old Jul 31, 2009 | 06:58 AM
  #403
javevo's Avatar
can not be reached at -30 with stock ecu?
Old Jul 31, 2009 | 03:20 PM
  #404
LeXcite's Avatar
Is this sound Bang Bang is always harmful for Turbo and ex.Valve? My Friend's tuned STI is always bangin with Lift-Of, and still no probs for 3 years ...
Old Aug 4, 2009 | 11:06 AM
  #405
Danieln's Avatar
You guys are really sure that you need SAS system in order to operate ALS on EVO?
I think can be done easy also from the ECU with the correct table if we will define that table properly.
This is some tables that I found in some other maps.
I really think that HKS ECU for Evo 9 has those tables defined also.
Just a thought......
