Evo anti-lag ECU disassembly
Old May 28, 2009 | 10:58 AM
  #376
Maikumaru's Avatar
ok let me see what I can come up with for you.
I dont have it on me...I have to get it off my buddies laptop
Old May 28, 2009 | 01:56 PM
  #377
mrfred's Avatar
Got your PM, and since you don't have the tables readily available, I went looking for the ALS subroutine myself. I easily found the ALS tables, but as I expected, they tables are not referenced to any code in the ROM. Next, I found the ALS subroutine in a JDM ROM and found its position relative to the main code branch. I followed the same path in the USDM Evo 88590015 ROM, and again as I expected, there is no ALS subroutine at that location. I wouldn't expect Mitsu to put it in some other location, so its clear to me that while there are ALS tables in the 88590015 ROM, there is no ALS code. BTW, this is also true for the 88840015/16 and the 96530006 ROMs. I haven't checked any other ROMs yet.
You sort of implied in your PM that your buddy actually wrote an ALS subroutine. That would be the only way ALS could be made to work properly on with an 88590015 ROM. Is that what he did?
Old May 28, 2009 | 02:09 PM
  #378
Maikumaru's Avatar
yes, I believe that is how he got around it.
if you look at the below menu...everything is referenced under "turbo"
from post 83 as reference
on my maps it is referenced as "als"
should be completely separate.
Give me the weekend to go through this more thoroughly.
Like I said, right now it is on some very mild settings...I think perhaps it was taken from the fq360 rom from geekmapped (right now).
I want to drill out the banjo bolts (inlets) to 1.5mm
and put some more aggressive timing and more air injection.
Old May 29, 2009 | 07:52 AM
  #379
mrfred's Avatar
88580013, 88580014, 88580015
The anti-lag code does exist in this ROM, so antilag will work provided that the hardware is installed (unlike the 88840014, 15, 16, and 96530006, and all USDM ROMs where there are only the tables and no code).
<scaling name="Timesecbyte" units="s" toexpr="x/10" frexpr="x*10" format="%.1f" min="0" max="25.5" inc="1" storagetype="uint8" endian="big"/>
<table name="ALS minimum vehicle speed to trigger" category="Turbo" address="1e12" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="Turbo" address="1e14" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="Turbo" address="1e16" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="Turbo" address="1e18" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="Turbo" address="1e1a" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="Turbo" address="1e1c" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="Turbo" address="1e1e" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="Turbo" address="1e20" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="Turbo" address="1e22" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="Turbo" address="1e24" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="Turbo" address="1e26" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Air injection time" category="Turbo" address="4e3a" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="7792" type="X Axis" elements="9" scaling="RPM"/>
</table>
Old May 29, 2009 | 08:54 AM
  #380
rodrig.diaz3's Avatar
</table>
Thats really awesome Mr Fred.
In wich part i must copy those text?
i know in the XML using wordpad but i dont know where to copy them.
Regards.-
Old May 29, 2009 | 09:43 AM
  #381
mrfred's Avatar
Regards.-
Search on "88580013.xml" in Windows. Open that file in Wordpad, and paste the entries before the final </rom> tag.
Old May 29, 2009 | 10:04 AM
  #382
Great MR fred can wait to try on my car.
Regards.
Old May 29, 2009 | 11:03 AM
  #383
silex's Avatar
Congrats! Your map appears to be out of the parameter input threshold as I see all xxx's.
</table>
It's nice to know that we can migrate some of the ROM's have the code in order to get ALS working on USDM Evo's. Another project to add to the to-do list.
Old May 29, 2009 | 11:15 AM
  #384
Maikumaru's Avatar
hey Silex,
no that is not a picture of my setup...I just snagged one of youngsyr's old pics from earlier in this thread as an example.
But for the details of how it was done I am not 100% sure, and I am afraid I am leading everyone down the wrong path...so I will be quiet for a bit
Right now...just to be a tease (sorry lol)
air injection is at 3k
and at speeds above 30kph
once I have the map switch installed...we will be lowering these and increasing air.
but I cant be driving around with this around here...lol
seems that cars tend to stay much further away haha...and I got some really interesting looks as I was getting gas last night.
tests this weekend with more aggresive settings.
Old May 30, 2009 | 09:49 AM
  #385
Maikumaru's Avatar
video posted here
https://www.evolutionm.net/forums/ec...sassembly.html
Old Jun 2, 2009 | 04:36 PM
  #386
got boost??'s Avatar
is it a 100% necessary to lower the timing in the low load zone?
if so, wich area specificly?
Thanks.
Old Jun 9, 2009 | 07:09 PM
  #387
laramie_05MR's Avatar
mrfred posted that the 96530006 does not have the coding for anti-lag.
looks like i will need someone to write the code for me. Any volunteers? I'm more than willing to donate to get this to work.
Old Jun 9, 2009 | 07:40 PM
  #388
mrfred's Avatar
It may be easier to switch to a ROM that already has the antilag code, e.g. a JDM Evo 8 ROM.
Old Jul 11, 2009 | 10:14 PM
  #389
spdracr's Avatar
would a USDM 8 beable to switch to a rom that has the ALS code?
Old Jul 11, 2009 | 10:48 PM
  #390
mrfred's Avatar
Probably, but to know for sure, I'd have to see the factory service manual for the donor Evo to see what solenoids are being operated by which of the PWM outputs on the donor Evo ECU.
