Evo anti-lag ECU disassembly
Ive cross drilled and enlarged the original holes...allows more air. As long as that banjo bolt seals on the exhaust manifold you should be golden.
The system uses a solenoid, just not the sas one. For the banjo bolts I used Nissan 240 powersteering ones, the hex has to be "trimmed" a bit, but they have bigger holes than the sas ones and because I put the hardware on late one night I couldnt buy any crush washers so I used regular ones, and to my surprise they work very well with only a slight leak on the number 3&4 cylinder side.
And as far as the solenoid goes I know it seems like I'm holding out, I just want to share everything at once. I promise as soon as I can can get the tables I need written and tested, everything will be posted on here in detail
. I have been testing, or I should say fiddling with this for two years now and the last thing I wanna do is put it out saying everything is good to go when there some tweaking to be done. I mean if I can get a coder to write me the tables
before next Tuesday then I can have the whole setup tested and posted by Wed. morningAnd if u guys got the hardware, all u need is the bov, tubes and banjo bolts, then basically when I have the tables u will only need to do a little setup and that's it, full functional anti-lag!!
Exactly right it just allows more to be injected.
I purchased evo 7 manifold and solenoid from japan, and evo 9 tubing and valve from UK (among other things as well which I forget now)
There is a guy in Japan who can do ALS with stock ECU also...
this is what he sent me; but he does not use ecuflash, so he has super secret sauce...maybe one of these trips I will get the chance to meet up with him...dosnt seem to aggresive though...but coo nevertheless
CT9A EVO8のOEM ALSのビデオです。
http://www.youtube.com/watch?v=WvbNdHJFclk
BOV-->you mean the SAS valve right?
Really cool about the 7 psi though...I wonder what is going on with my setup then...
Ill keep quiet and wait for your post, no worries!
I have everything setup from factory (JDM 7)
Banjo's are drilled from 3mm to 7mm.
All tables are modded, but still nothing.
Apparently its due to the EGR being open same time as SAS valve.
Wow, seems like a lot of work. All I have to do is plug in lap top and setup the anti lag function to produce what ever boost I want, have it turn on after a certain RPM is reached and have it turn back off after what ever amount of time or RPM I would like it to turn off at. Autronic FTW!
On your autronic what do you use for the throttle kicker? A Ford Falcon IAC or a solenoid. If its the IAC/solenoid we have another option for that as well. My car is using just the IAC and an optional "kicker" solenoid. Andrew's is more intense...makes me jealous actually
Flicked a switch that was setup to the ECU and suddenly revs rose to ~1500, and the idle was much angrier.
Aaron
Yeah the local guy that supplied/installed it ~6 years ago, is an Autronic fanatic.
Has been supplying/installing/tuning 4G rallycars around Australiasia for decades.
Good mate owns the car now, i'll take some snaps of the setup next time I see the car.
EDIT: oops, just re-checked, and its the opposite, disable is set to 1 is how I understand it.
