Evo anti-lag ECU disassembly
Old Mar 13, 2008 | 12:12 AM
  #106
nod911's Avatar
Originally Posted by silex
Is ALS now working on the EVoIX?! WOW!
On the JDM version yes
Old Mar 13, 2008 | 12:31 AM
  #107
kkarim's Avatar
will it ever be possible to make this work without the SAS? Maybe using a throttle kicker or something similar...
Old Mar 13, 2008 | 01:38 AM
  #108
BarryC's Avatar
Originally Posted by nod911
Okay the ralliart E7 rom has the same locations as the normal E7 rom.
Attached are the XML for
JDM7 : 98640014
Ralliart JDM7 : 90550001
JDM8 : 93660005
8MR : 96260007
All of the above XML's show the air injection table zero'd out on my ecuflash.
If you are manually copying these tables over to your existing XML then If the air injection table doesnt show zero's then you either have a different ROM ID or you forgot to copy the scaling across also. at the top of the XML there are 2 scales (rmpsecbyte and timesecbyte...something like that); make sure you copy these across to your XML as well.
and remember for full benefit you have to retard the ignition timming in the 'back off' areas of your ignition maps (say <30 load and >4000rpm)
excellent work mate
cheers for that.
now to test it
Old Mar 13, 2008 | 02:25 AM
  #109
Youngsyr's Avatar
Originally Posted by cossie1
Rob I have emailed you a working version of your def file now
I missed the same lines off yours too lol
Many thanks Russ, much appreciated! There won't be many Evos in the UK without pops and bangs now?!
Old Mar 13, 2008 | 02:26 AM
  #110
Youngsyr's Avatar
And everyone was blaming me, hahha. jk.
did you miss the timesecbyte scaling? or something else?
Well I had to blame either you nod911, or Cossie1, and he lives about 10,000 miles closer to me than you!
Seriously though, excellent work on the dissassembly. You've made a lot of people very happy (and their neighbours completely the opposite)!
Old Mar 13, 2008 | 03:40 AM
  #111
BarryC's Avatar
one quick question is it possible to find the timing retard limit table???
this table is defined in ecuedit and it sets the maximum ammount of timing retard that can be set into the rom.
but in ecuedit the address is wrong, if we could find this it would mean we could have the timing set to -10 same parameters as in the Autronic ecu.
and then we will be able to run full antilag if required.
its just another option to play with.
Old Mar 13, 2008 | 03:51 AM
  #112
nod911's Avatar
do we kow what the current timming limit is?
Old Mar 13, 2008 | 04:45 AM
  #113
BarryC's Avatar
yep its -5 degrees.
no matter what ya set the timing to in the maps it will never go below -5,
and for to run the antilag we need to be able to retard the timing to around -10 or -15, cheers mate much appreciated.
Old Mar 13, 2008 | 04:50 AM
  #114
Youngsyr's Avatar
Originally Posted by agron25
j ai modifier le xml pour la EUDM
mais pas encore fait les essaie
je vous tiendrait au courant si ca marche ou pas
Bien entendu, j'attends tes nouveaux.
Il me semble que t'es assez fort en anglais (plus fort que moi en francais sans doute!), mais si tu auras jamais besoin d'un petit peu de traduction, n'hesiter pas de me demander!
Old Mar 13, 2008 | 06:19 AM
  #115
cossie1's Avatar
Originally Posted by BarryC
yep its -5 degrees.
I did think this was possibly due to using the standard cams, but now you have said that, I guess it's not as your now on the GSC's.
Old Mar 13, 2008 | 07:20 AM
  #116
Youngsyr's Avatar
It's not looking good for sourcing the SAS hardware from my mechanic, but I've put some feelers out and there are a couple of spare units knocking around the UK forum.
I'm just trying to get the owners to commit to a price they're willing to sell at...
Old Mar 13, 2008 | 07:36 AM
  #117
BarryC's Avatar
No Russ I found a table called mimimum timing retard, in one of the rom definition files which suggests like the antilag tables Mitsubishi have disabled this in the road production vehicles but its there for motorsport use,
it seems that this parameter is set to -5 so the timing cannot be retarded any lower than this,
if we can find this table it will mean we can set the timing way lower for more effect lol.
there is a downside of higher EGT's so we have to take small steps with this,
also we might have to drill out the banjo bolts for the SAS pipework going into the exhaust manifold for full effect as the stock holes are not so big,
Some testing is required.
Old Mar 13, 2008 | 07:46 AM
  #118
cossie1's Avatar
A guy I know that does rallying has told me before to drill the banjo's out by 1.5mm or to 1.5mm (will need to check) to get the system to work better and smoother.
He said it's something they always did to the rally cars.
Old Mar 13, 2008 | 08:25 AM
  #119
BarryC's Avatar
excellent
out with the drill later so
Old Mar 13, 2008 | 11:46 AM
  #120
silex's Avatar
Can this map be added to the USDM rom? We have the ALS disabled in ours too. Do we need the added hardware to take advantage of this?
