Intercooler spray disassembly/explanation
Old May 9, 2007 | 03:29 PM
turbrodude's Avatar
When I click on IC Relay Air Temp, I can't read the number because the window is too small. It says "2...". If I press "+" some 80 times it says "3...". Then I press "-" 100 times and it goes to "1...", so now I know that each click is 0.1 degrees C and it started around 24 degrees C. Is there a way to see the numbers though?
Also, can you change the IC Relay Control Vehicle Speed? It doesn't seem like it will edit.
Old May 9, 2007 | 04:12 PM
C6C6CH3vo's Avatar
Sounds like your definition isn't a match, there should be 3 digits to fit in there
Old May 9, 2007 | 04:52 PM
turbrodude's Avatar
That's what somebody else mentioned, but I don't quite understand this definition, XML, ROM thing yet. How do I get the right definition? Where do I get it? I have a '03 evo and just recently downloaded ecuflash 1.3.
Old May 9, 2007 | 06:21 PM
cpoevo's Avatar
Here are the numbers from my untouched '03.
relay timer time on 20.5 off 18.4
timer control judgement hi .06 low 2.34
timer air temp 215
timer ON mde switch time 0
timer control RPM 3500
timer control water temp hi 105 low 100
vehicle speed 100
EV 50
Old May 9, 2007 | 06:43 PM
C6C6CH3vo's Avatar
right click the air temp parameter and edit, what is the scaling at?
If it's temp then the xml needs to be edited which I havent tried yet so I can't help
Old May 10, 2007 | 12:52 AM
finevo9's Avatar
http://www.mrtrally.com.au/performan...IX-ICSpray.pdf
Old May 10, 2007 | 09:18 AM
turbrodude's Avatar
Yah, it says 'temp'. So can anybody here give me the 3 step easy answer as to how to find the correct XML file?
Old May 10, 2007 | 10:27 AM
C6C6CH3vo's Avatar
What I would try is do a search on your computer for all xml files with your vehicle year as included text.
Find the file with your ID and see if the IC addresses matches, but it probably would
Old May 10, 2007 | 12:46 PM
honda-guy's Avatar
nice, i'm going to use their recommened settings.
Old May 13, 2007 | 10:59 AM
turbrodude's Avatar
timer air temp 215
vehicle speed 100
EV 50
That's what mine are at (although its hard to read because of what I mentioned above), but why on earth would they have the air temp parameter at 215??? If that's measured at the air filter (like the MRT pdf file says) than you'd have to be driving on the sun for the sprayer to ever turn on. Is it really measured at the airbox? Or is there a manifold air temp sensor?
Old May 13, 2007 | 11:15 AM
cpoevo's Avatar
Air temp is measured through the MAF I believe.
Old May 13, 2007 | 11:40 AM
turbrodude's Avatar
I thought it was measured through the MAF as well, but then why is the temp set at 200+ C?? That frigin hot. All I can think is that the XML file I have makes the number appear incorrect. If that's so, then its pretty scary because you could think that you were adjusting one parameter, but you were really affecting something else... or something like that. I don't know what I'm talking about.
Old May 17, 2007 | 10:21 AM
Jorge T's Avatar
timer air temp 215
vehicle speed 100
EV 50
Mine are the same, why are they so whack on the first 3 items listed? Not even close to what documented on the pdf or is the xml def incorrect?
tephra
Aug 19, 2016 10:07 AM
jcsbanks
Jul 17, 2016 05:50 AM
Jim in Tucson
Nov 21, 2010 09:29 AM
rob82
Jan 15, 2008 07:35 PM
