Installation and Tuning for Perrin EBCS...
Old May 20, 2007 | 08:05 PM
RazorLab's Avatar
Originally Posted by subaruwrx420
I also messed around with the Turbo Boost Correction Table. Initially had all the values to 0 since it supposed to be easier to nail boost targets. Then I decided to increase the negative values as shown below to allow the ecu to reduce the boost if the targets are being overshot.
Hardest part about tuning ecu boost is the error correction kicking in with BDEL and WGDC not synched up just right. Making it pull more boost by increasing the negative values will actually make it harder to tune it. It will also pull boost much more aggressively in higher gears which will lead to a swinging boost profile. You're actually not doing yourself any favors by doing that.
I actually keep the TBEC table stock on all the ecu-based evos I tune. Zeroing it out will make setting boost via WGDC easy as no error correction will be happening. However, if you get your WGDC table set right and then set your BDEL table, then turn the TBEC table back on and don't have your BDEL's just right, your boost will be all over the place. I learned it's actually easier in the long run to just tune it with error correction on from the start.
Old May 5, 2013 | 02:12 PM
mufasa39's Avatar
Perrin
This is some good info, I have one but just haven't gotten around to tossing it on because of the tuning process yet. It will be soon but I have to tune it myself.
Careyalfie
Mar 20, 2017 10:06 PM
Paulevo9
Aug 15, 2015 09:02 AM
efmathis
16
May 9, 2015 06:37 PM
AlvinHuyN
For Sale - Cars For Sale
Jun 17, 2013 04:11 PM
hachansoo0413
Jul 11, 2012 09:41 PM
