94170008 ROM 2 byte load mod for dummies (like me :)
Old Mar 9, 2008 | 11:24 AM
  #61
Warrtalon's Avatar
Edit: Nevermind - just learning the basics.
Old Apr 10, 2009 | 06:33 AM
  #62
evolv's Avatar
I can confirm If you make a backup of the xml file do not leave it in the rommetadata folder! Not sure how ecuflash picks the file but it seems to use the backup instead of the orig.. cheers
Originally Posted by erioshi
A418t81, thanks for the response.
I actually found my problem was something completely different. I had created an "XML Backup" folder inside the Evo folder and made a copy the original file there keeping the original name. Once I changed the name of the xml file in my backup folder my modified xml file (in the Evo folder) with the new maps loaded correctly.
Thanks for posting the working file, however. It was comparing yours to mine (and having yours fail when I tried it) that lead me into looking for alternative causes for my problem.
Old Nov 6, 2009 | 04:19 PM
  #63
NightCat's Avatar
Im using EcuFlash 1.42, can I just save that .txt file as data.xml and have the ability to log 2byte? just sorta confused about how to use 2byte with EvoScan and ECUFlash.
mrfred
Dec 15, 2022 11:13 AM
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
Pd1
Oct 11, 2009 05:17 PM
chmodlf
Aug 24, 2008 01:17 PM
