Lean spool qestions....
Old Jun 13, 2007 | 06:45 PM
  #46
taenaive's Avatar
Originally Posted by occultworks
Change the address of "anti-lag stop" up 2 and it will be an rpm value. Don't know if you knew this taenaive, so I thought I'd point it out.
Yes, I have that already and mine is set at 7300rpm. I am kinda convinced that anti-lag stop is AFR. I rasied the value of anti-lag stop and the lean condition below 2500 is now rich condition.
Old Jun 13, 2007 | 10:34 PM
  #47
mrfred's Avatar
It is an AFR value. Increasing the value should create a leaner condition below 2500 though. My current 88590015.xml file is attached. There are several tables that are not yet fully defined. I don't recommend messing with those. :-)
File Type: zip
Old Jun 14, 2007 | 04:30 PM
  #48
taenaive's Avatar
AFR value should go down if you increase the value. Your AFR16 definition is telling me the same thing.
Anyway, Do you have addresses for 96940011?
