Help!!!!!!!!!!
Old Jun 5, 2007 | 03:11 PM
  #61
I Kill Suckers's Avatar
then where is the number that does
Old Jun 5, 2007 | 04:08 PM
  #62
laakness's Avatar
Damn, that was one expensive click of the OK button. I guess that's why you have to hit it a second time.
Make sure it's a flatbed since this car is AWD
Old Jun 5, 2007 | 07:35 PM
  #63
thanks...smart ***
Old Jun 5, 2007 | 08:38 PM
  #64
laakness's Avatar
I guess it's to be expected now days with computers everywhere and everyone thinking "you can't break it, it's a computer, you can just reconfigure it".
Where's did that slight amount of fear go that would have made you go..."oh, I'm going to **** with the brain of my car...I wonder if I should do a little research for any of the dangers"
Old Jun 5, 2007 | 09:56 PM
  #65
wrcwannabe's Avatar
Contact Malibu_Jack at Aktivematrix.com If anyone can help he can.
Milburn
Old Jun 6, 2007 | 03:26 AM
  #66
jcsbanks's Avatar
I don't have my label to hand, but why not post all the numbers/letters on it or a pic?
IIRC, MN and then many digits are one of the codes on mine.
Old Jun 6, 2007 | 03:41 AM
  #67
gunzo's Avatar
Well .. since he screwed up the ECU with a ROM that was flashed in .. why not just post the ROM that was flashed in?? He should have that .. and he should be able to change the values on that rom image ..
Old Jun 6, 2007 | 05:24 AM
  #68
jcsbanks's Avatar
Did he flash the correct image though? ECUflash doesn't stop you...
You're in luck perhaps - 1860A118 is the same as MalibuJack shows on his bench harness and he said it was 94170008. You can download a standard version off Aktivematrix (need to register). Then read up on the ECU periphery bytes, disable the immobiliser bit and try flashing that to your ECU.
Old Jun 6, 2007 | 09:02 AM
  #69
Mad_SB's Avatar
Originally Posted by I Kill Suckers
thanks...smart ***
Dude,
These folks are not being smartasses. The problem is you f'd up your ecu cause you did not take the time to understand what you were doing. There is a tutorial in this forum (yes I know it is not a stiky and it should be but I'm not a moderator so I can't make it a stiky) that explains the whole process, what to do and what not to do and why.
Pull out your stock ecu (the physical unit located behind and to the left of the glove box) and write down ALL the numbers on the factory label. the ecu id should start with MN IIRC.
You need to get a stock rom that matches your ECU ID then try to set the I.C to FFFF as mentioned earlier. Flash that in and see if that helps.
If you can get the ECU ID (if you not sure, pull yours out and take a picture of any and every label on the case and post them up) and you ask nicely you may be able to get someone to disable the I.C. using the ecu periphery method.
Old Jun 6, 2007 | 10:44 AM
  #70
Originally Posted by mad_VIII
Dude,
hey, i kno i f'ed up..I am taking a picture of it now. And i have been nice to everyone that has been helpful to me. The only reason i said " smart *** " was becasue i really dont need someone comming into the thread and telling me i messed up I already kno i did..
Old Jun 6, 2007 | 10:48 AM
  #71
Heyy ya that code is under Stock 03 Evo8....I have an 05 will that be fine?
Old Jun 6, 2007 | 11:58 AM
  #72
jcsbanks's Avatar
Seems to match your ECU case, so that is the one I'd try first.
I will post up a modded image on aktivematrix for you to try.
Old Jun 6, 2007 | 12:28 PM
  #73
yo it worked....I LOVE U...no homo....thnx bro soo much
Old Jun 6, 2007 | 02:53 PM
  #74
jcsbanks's Avatar
Old Jun 7, 2007 | 05:08 PM
  #75
sharkm87's Avatar
yay...alls done...what have we learend folks
