AFR Gauges and Sensors
Old Jun 11, 2007 | 02:28 PM
mdsevo06's Avatar
Where do you pick one up?
Old Jun 11, 2007 | 02:42 PM
kreionic's Avatar
where do you pick what up? The LC1 can be gotton at innovate.com or other vendors on here sell them aswell
Old Jun 11, 2007 | 05:53 PM
TouringBubble's Avatar
Best price for LC-1 I've found
Old Jun 21, 2007 | 01:39 PM
Thoe99's Avatar
Do I need to buy this USB to serial cable if I'm going with the LC-1? I'll be using it with a laptop and Evoscan.
http://www.axceleratedmotorsports.co....cfm?ProdID=49
Also, how does it attach to the exhaust? I have a downpipe with cutout (dumps straight out from a bypass valve off the downpipe), so I don't think I can use the stock o2 port off of the catback. Do I need to drill a hole in my downpipe?
Old Jun 21, 2007 | 01:41 PM
recompile's Avatar
You will need the adapter.
Just get this: http://www.newegg.com/Product/Produc...82E16812119002
kreionic's Avatar
Do you have a serial port? If not then yes. The bung for the o2 sensor goes 18" from your turbo. So yes on your DP
Old Jun 21, 2007 | 01:49 PM
Thoe99's Avatar
What does the bung look like? Is it a clip that I can just attach to the open part of the cutout valve? or do I really have to drill a hole in the downpipe (I'm trying to avoid a permanent install if possible). Does the link below come with a bung?
http://www.axceleratedmotorsports.co....cfm?ProdID=47
Old Jun 21, 2007 | 01:56 PM
kreionic's Avatar
Hmm if your trying to avoid a perminat install you might want to look at the innovate lm1.
The bung looks like a little ring but thick. You need to tap your dp and then weld the bung in there. The bung should come with the kit. It also comes with a plug for the bung. So you could take it out but you soder the wires in. I got mine from innovate. TouringBubble got his from there he can tell you but it should come with everything.
Look at the LM1 I think thats what you want
http://www.innovatemotorsports.com/products/lm1.php
benIX
Aug 12, 2012 08:56 AM
AV6JT
Jul 15, 2012 05:48 PM
monkeyevo
Nov 13, 2010 01:20 PM
Evasive EVO
12
Aug 23, 2010 08:41 AM
EmeryatSTM
11
Nov 28, 2008 08:42 AM
