Pocket PC logging now working
#136
Here is the latest version:
COM1 19200baud
Live graphing of octane, knock, MAT, IAT, MAP, TPS
Live scatter plot of knock vs RPM - red if TPS=100, blue if >90, green otherwise
Logging to SD card in .csv format
Setup for 240*320 display
Temps in Celcius, pressures in kPa
MAT,MAP are Evo IX JDM/UK calibration, will return junk values on US models
Tested on Pocket PC 2003SE, runs under .net compact 2.0
Logs as fast as the PC based loggers.
Requires VS2005 trial or full version to compile.
Do no think of this as a consumer release, it is my project of which I'm sharing the code. I'll not be able to support it although will be interested in other deployments.
COM1 19200baud
Why do I need this .net compact to run your logger?
#140
john - the new ftdi driver should install the COM port as well. I still haven't received the USB host cable for my Acern50 to test this - but here is the link http://www.ftdichip.com/Drivers/VCP/...4VCPDriver.zip
may be you can get it work and talk you logger to the com port to te tactrix cable.
#142
Just to update - I have managed to get the Tactrix cable working and logging into a PDA (Acer n50 - with USB host support) - using some kind of test software (build based on johnbank's serial logger). Once I get it cleaned up - I will post.
#144
I posted all the details here:
https://www.evolutionm.net/forums/sh...6&postcount=65
Broke4speed
Aug 6, 2017 07:57 PM
