HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
cij911, I believe if you zero out the boost error map from 0 to -20 that means you don't have any underboost correction which it seems like is happening with you going 20 and then dropping to 15 and staying there.
I am going to hook up an MBC over the weekend and see what results that yields....Thanks
Several ways: (1) Adjusting WGA and target load did absolutely nothing with boost -- i just ran basically WG boost (2) installed MBC and was able to run fine...(3) I have not tested the unit itself but will later this week....(4) I got a bad WGA code...I believe it was TP224...
did a log tonight and my boost did a wierd dip right around 4k. this was on a third gear WOT pull starting at about 2700rpm. I spiked at 25.6 psi then it just dipped to about 22 and then tapered off to about 20. I usually can hit around 26-27.5 psi with these same settings and it will just gradually taper to 20 to redline. Could it just be my correction because I hit over 330 load and my BDEL only goes to about 310 here is a look at the graph and my settings.
thanks,
ed
thanks,
ed
I actually usually hit between 26-27+ psi doing a third gear pull like this one. Should I adjust my offset and BDEL to reflect my third gear pulls? how will this effect when I do a 1st gear and up pull? When I do a 1st-3rd gear pull I usually only see about a max of 305 and lower load and it follows my existing BDEL+offset.
thanks,
ed
Actually I'm not overshooting my boost, my load just seems to be spiking
thanks,
ed
thanks,
ed
Update, the AEM solenoid didnt work at all when connected to the ECU with 2 resistors (load was 32 ohm using 2 1W 10ohm resistors). I played with the #60 pill a little and hooked the AEM solenoid back up to the truboost gauge and I'm going to work with it and get the GM 3port.
Well I am having a hell of a time getting the car to hold / hit boost like my two previous setups (MBC and modified stock BCS). My target peak load is ~159.4 + 105 @ 3000 rpm, tapering to 120 + 105 @ 7000 RPM and for some reason I seem to be ~ 15 - 18 psi in third / fourth gear and closer to 20psi in 6th. My MWGDC were 100 up to 3000 rpm and then 75 to 7000 rpm.
Shouldn't a load of ~265 be like 21psi @ 3000 rpm (the car is acting like it is trying to be at 15psi)?? Any ideas on what could be going on with my setup? (I did have different configurations for tables #1 and #3.) Thanks
...Should be an easy fix once the new one arrives....MBCs sure are easy
