2.1 bar boost on Evogreen - What timing???
Old Jun 29, 2007 | 04:01 PM
Oracle1's Avatar
Running 2.1 bar boost on Evogreen (1.9bar @ 3.9k rpm), what timing should I be aiming at to make it worthwhile running 2.1 bar ?
TIA
Old Jun 29, 2007 | 04:22 PM
1mad evo's Avatar
what fuel?
Old Jun 29, 2007 | 04:24 PM
05WhiteEVO8's Avatar
Hopefully C16 with that much boost.
Old Jun 29, 2007 | 06:25 PM
C6C6CH3vo's Avatar
TIA
My wife and I agree that late timing is better than early.
Timing depends on the A:F, but the A:F depends on your parents
Old Jun 30, 2007 | 04:21 AM
Oracle1's Avatar
LOL
I am running 99 shell v-power (UK).
Please do not slate me (or this thread), I just want an indication so I can try out a few tests before deciding what is a good boost level to set.
A/F is 11.6 in 3rd gear.
Old Jun 30, 2007 | 06:39 AM
Mellon Racing's Avatar
I don't think you're going to get a clear answer... log a run, make sure the AFR is where you want it, bump up the timing if it isn't knocking and figure out what works best for your car.
Old Jun 30, 2007 | 01:02 PM
jrsimon27's Avatar
21.bar is 30psi on 99ron whick is like 94mon you must be knocking be carefull or your engine will go boom.
2.1x14.508=30.4psi this is to much for 99ron
do a log as mellon says and post it up use evoscan
Old Jun 30, 2007 | 02:09 PM
burgers22's Avatar
Why do you say he must be knocking? Ok there is not to much info to go on and you would really have to be careful, but it's still not to say there is definitely knock at that boost.
MB
68wsteve
Dec 13, 2010 10:18 AM
Vivid Racing
17
Mar 3, 2008 04:16 PM
nitz
Jan 24, 2008 12:20 PM
nitz
Jan 22, 2008 08:56 PM
Tsurugi-san
11
Aug 21, 2007 08:15 AM
