tuning for unleaded vs. leaded race fuel?
Old Jul 11, 2007 | 12:51 PM
EVO8LTW's Avatar
I'm going to work on developing a race gas tune for my car and was wondering whether there is much, if anything, to be gained with 110 leaded vs. 100-104 unleaded, in terms of knock resistance when using a derivative of the stock turbo. Is it worth the wear and tear to the O2 sensors to use leaded race fuel? I was hoping that someone here has tuned on both and can speak to the difference.
Thanks!
Old Jul 11, 2007 | 02:35 PM
RazorLab's Avatar
If you are not looking for every last ounce of power for dyno bragging or drag racing I would just use a good 100-104 unleaded gas and tune for that on a stock turbo
The leaded works well when you are asking for big **** boost from the stock turbo, again to eek every last ounce of power from it.
Old Jul 14, 2007 | 05:30 PM
Mellon Racing's Avatar
c16, the sweet nectar of the gods
Old Jul 14, 2007 | 05:32 PM
EVO8LTW's Avatar
One thing about the leaded (110, not C16) is it would be much much less expensive. Not only does it cost less per gallon, but you could use less mixed with 93 to get to the same octane level.
Old Jul 14, 2007 | 05:56 PM
nothere's Avatar
that was the trick a long time ago, mix leaded with unleaded regular for a big jump in octane.
Old Jul 14, 2007 | 06:10 PM
C6C6CH3vo's Avatar
If your tuning on leaded just make sure there's an extra O2 sensor in the trunk. Lead supposed to accelerate the sensors death
Old Jul 15, 2007 | 06:19 AM
No doubt, when I was racing my Stealth twice a week on leaded gas, the WB02 sensor would last about a month or two and start flaking out. Also the plugs would start sputtering.
I've since regulated my cars to pump gas and haven't had a single problem.
Old Jul 23, 2007 | 12:37 PM
Jeff_Jeske's Avatar
^ I've run at least 100 gallons of 110 octane turbo blue through my car and the O2s have never had a problem. I have heard that its not good to run leaded fuel on a brand new sensor and its not good to do it back to back to back.
I run leaded for lapping days and "special" weekends only not daily.
Old Jul 23, 2007 | 02:25 PM
fastrob691's Avatar
Ive noticed the leaded loads the plugs when you leave the track and go back to pump driving anything less that WOT, just my experience, I just cant find 100 octane in this part of NM, so been running Torco 114, .
stroked4g63
E85 / Ethanol
Dec 9, 2013 09:12 PM
adam_79_2005
Apr 2, 2011 05:38 AM
bukhumnoi2000
Northwest Region
17
Sep 27, 2008 06:05 PM
ccboy37373
Jun 30, 2008 12:24 PM
sno_evo
Apr 20, 2004 09:23 PM
