adding extra cells to get to 300 load
Old Jul 16, 2007 | 12:46 PM
  #46
Oracle1's Avatar
I was told not to run 2 byte load. When did the Doc do this?
Old Jul 16, 2007 | 12:50 PM
  #47
Mellon Racing's Avatar
Originally Posted by Oracle1
High octane maps as my octane is reading 100. Also knock shows 0.
factors other than knock can affect timing values actually used
Old Jul 16, 2007 | 12:58 PM
  #48
Oracle1's Avatar
Which other factors?
Old Jul 16, 2007 | 01:07 PM
  #49
burgers22's Avatar
Was this in reference to the logger or to modding your ROMs MUT table? No problems using the modded rom as far as I know.
If your running a JDM FQ360 I think JB has posted the locations, it's not to hard to find using disassembly ( only after JB walked me through it though! )
MB
Old Jul 16, 2007 | 01:09 PM
  #50
Oracle1's Avatar
Not the logger.
I was told the ROM will trash my MAP. How long ago is this?
Old Jul 16, 2007 | 01:46 PM
  #51
burgers22's Avatar
Not the logger.
You only need to change the values in the request Ids 00 and 01 in the MUT table. None of the other maps are touched. Who told you it would trash your maps? Did they give a reason?
MB
Old Jul 16, 2007 | 02:18 PM
  #52
Oracle1's Avatar
Nope. The Doc...
'Never mess with the Doc'...
Old Jul 16, 2007 | 02:20 PM
  #53
JohnBradley's Avatar
Odd, I havent noticed any issues?
Old Jul 16, 2007 | 02:24 PM
  #54
burgers22's Avatar
Nope. The Doc...
Really?!!
Well I am surprised....very odd, blimey.
But, as you say, never mess with the Doc...still strange.....
MB
Old Jul 16, 2007 | 02:31 PM
  #55
Oracle1's Avatar
I am sure he will come along and confirm...
Old Jul 16, 2007 | 03:09 PM
  #56
jcsbanks's Avatar
No reason not to run 2 byte load Oracle, it won't mess anything up. It wouldn't have been any use on your original IX turbo setup with the scaling at 300 with your HKS induction that lowers your load values. As long as you're getting predictable ignition and knock sums I wouldn't bother, but I suppose it is all more data to gaze at if you are curious, and might reassure you that you're ignition isn't falling off the edge of the world and put you at risk of rediscovering America
Old Jul 16, 2007 | 03:16 PM
  #57
jcsbanks's Avatar
You can change the size and shape of the tables if you move them to some spare real estate in ROM, it is quite easy to find spare space, that is where I've put new routines and maps that don't get overwritten. However, like 2 byte load most of the time it is probably fairly pointless. I think I could make a nice map with 3x3 tables since they are interpolated.
Old Jul 16, 2007 | 06:17 PM
  #58
gunzo's Avatar
John for IX, there is a possibility of screwing up the ROM .. or readings .. especially when the ID 00 and 01s are over written with the 2byte load ..
you'll get a funny 2byte load and ignition timing at a constant -20 ..
Old Jul 16, 2007 | 06:32 PM
  #59
tephra's Avatar
you must have done something wrong then..
what ROMID u got?
Old Jul 16, 2007 | 06:58 PM
  #60
gunzo's Avatar
what ROMID u got?
Well .. that's what I thought .. but nope .. it was correct .. you're unable to read .. and I'm thinking it could be the codes .. so now I got to spend time delving into MUT routines
the ROM id is 80930002 you guys don't have this version I believe
