adding extra cells to get to 300 load
Old Jul 16, 2007 | 07:02 PM
  #61
tephra's Avatar
hrmm be careful when identifying the MUT_HEAD, you can easily get it wrong as there are set's of 0xFFFFXYXY's before the real MUT_HEAD...
Old Jul 16, 2007 | 11:27 PM
  #62
gunzo's Avatar
YOU ARE RIGHT !!
That explains why mine reads so weird !!
Staring too much at numbers nowadays !
Thanks
Old Jul 16, 2007 | 11:33 PM
  #63
tephra's Avatar
lol! glad to be of service!
Old Jul 17, 2007 | 12:32 AM
  #64
burgers22's Avatar
Can you clarify? Here is the MUT from IDA, jcsbanks identified in my ROM, I added the < notes >
ROM:0002E9D8 mov r4, r0
ROM:0002E9DA rts
ROM:0002E9DC mov.l @r15+, r5
ROM:0002E9DC ; End of function sub_2E9B0
ROM:0002E9DC
ROM:0002E9DC ; ---------------------------------------------------------------------------
ROM:0002E9DE .data.b h'FF < start of MUT table >
ROM:0002E9DF .data.b h'FF
ROM:0002E9E0 unk_2E9E0: .data.b h'FF ; DATA XREF: ROMff_2E998o
ROM:0002E9E1 .data.b h'FF
ROM:0002E9E2 .data.b h'87 ; ç < Request ID 00 >
ROM:0002E9E3 .data.b h'B3 ; ¦
ROM:0002E9E4 .data.b h'FF
ROM:0002E9E5 .data.b h'FF
ROM:0002E9E6 .data.b h'87 ; ç < Request ID 01 >
ROM:0002E9E7 .data.b h'B2 ; ¦
ROM:0002E9E8 .data.b h'FF
ROM:0002E9E9 .data.b h'FF
Any pointers would be great.
MB
Old Jul 17, 2007 | 02:05 AM
  #65
tephra's Avatar
well the last couple of ROM's ive been looking at have several sections of 0xffffXYXY's before the real mut table.
sometimes its easy to think the first section is the mut table...
Old Jul 17, 2007 | 03:16 AM
  #66
Oracle1's Avatar
Originally Posted by jcsbanks
No reason not to run 2 byte load Oracle, it won't mess anything up. It wouldn't have been any use on your original IX turbo setup with the scaling at 300 with your HKS induction that lowers your load values. As long as you're getting predictable ignition and knock sums I wouldn't bother, but I suppose it is all more data to gaze at if you are curious, and might reassure you that you're ignition isn't falling off the edge of the world and put you at risk of rediscovering America
Hmmm Data...
Old Oct 22, 2007 | 07:26 AM
  #67
vroomevo's Avatar
one of evo guy in local showed me the very easy way to add additional column in ecu load.
first click on high or low octane/fuel map, click 'edit', scroll down to 'edit map definition'. then you will see 'data values...', 'x-axis load', and 'y-axis RPM'.
if you change 'elements' under 'x-axis load' then you will get additional column on load section. for example, my elements is 18, if change it to 20, then it will give me 2 more columns for additional load.
i don't know if this is covered in the past, i am not sure if this is the right way to do it. expert can comment on it.
thanks all.
Old Oct 22, 2007 | 07:41 AM
  #68
tephra's Avatar
yeah like I said in the other thread dont do that
Old Oct 22, 2007 | 07:49 AM
  #69
fastrob691's Avatar
So if you hit load values say 20 higher than the max, is there something like a fuel cut, I noticed when tuning that on one run I hit 322 load and it acted just like fuel cut, I have not rescaled yet. So my max is still 300.
Old Oct 22, 2007 | 07:50 AM
  #70
l2r99gst's Avatar
Yes, please don't do that. The space in the ROM where the maps are have no more room to add more columns in the way that you mentioned. Doing it that way, you would be overwriting other data in the ROM.
Eric
Old Oct 22, 2007 | 07:51 AM
  #71
TouringBubble's Avatar
I don't think there is a cut directly associated with overshooting the tables. It's more likely that you overshot the boost limit table.
Old Oct 22, 2007 | 08:09 AM
  #72
fastrob691's Avatar
That would make sense, I was working on my race gas tune, as well as playing with the HP/TQ logger and hit a little over 29.2 psi(JDM map) where the "Cut" seemed to happen and it recored 322.2 2 byte load.
Old Oct 22, 2007 | 01:23 PM
  #73
Mellon Racing's Avatar
I agree, I've had plenty of cars come to me going way over the 260kpa load on evo 8's and 300kpa load on evo9's without hitting fuel cut.
Old Oct 22, 2007 | 01:27 PM
  #74
JohnBradley's Avatar
Once its off the grid it goes into some rapidly decaying interpolation function though. So it might not hit fuel cut or boost cut but it still drops power.
Old Oct 22, 2007 | 02:04 PM
  #75
RazorLab's Avatar
Indeed, seen it many a times.
