Installing Wideband Suggestions
I always install Wide Bands with the wire going through the same place as the factory 02 sensor wire. If you pull out the passenger seat you can see there is a slot in the carpet, underneath it there is a small hole that you can run the sensor through and then just cut the rubber boot a tiny bit to allow it to be used again with extra wires in it. This way I can leave the LC-1 controller or whatever unit I am using underneath the carpet under the passenger seat. It makes your wiring extremely short and keeps everything nice and neat. You do have to enlarge the hole a TINY bit to allow the sensor to pass through easily, a dremel works great.
cij911
139
Mar 19, 2021 04:19 AM
botemarc
Jul 22, 2014 05:41 PM
GinNBoost
May 25, 2008 08:01 PM
