immobilizer code is 0001
Old Jul 14, 2007 | 06:38 AM
shadow1's Avatar
My car has previously been flashed by Dynoflash. It starts and runs fine. While I was studying my fuel maps for tuning, I looked at my immobilizer code out of curiosity. My code is 0001. Seems to me like the code ought to be a little more than that. Any thoughts? (and no, I am not mistaking this for the init code).
Old Jul 14, 2007 | 06:49 AM
joedr's Avatar
EvoM Moderator
What is the code on the keys? There should be a tag with the two set of keys that you received (if bought new) from the dealer where the immo number was written.
If they match, then .... well your Immo is 0001. Let me know!
This is back of my head and anyone can correct me if I am wrong!
Old Jul 14, 2007 | 09:03 AM
kreionic's Avatar
Are you sure you looked at the immobilizer and not the init code?
Joedr I don't think that the immobilizer code on the key chain. I know on mine that was not the immobilizer code.
Old Jul 14, 2007 | 01:40 PM
shadow1's Avatar
As I stated. I'm NOT referring to the Init code. My Immobilizer code is 0001.
Old Jul 14, 2007 | 01:43 PM
Planet Evo's Avatar
Is the init code 0001 as well? If not then....
Just out of curiosity.
Old Jul 14, 2007 | 01:45 PM
shadow1's Avatar
My init code is 0001 as well.
Old Jul 14, 2007 | 01:47 PM
Planet Evo's Avatar
Are you able to read the whole rom or was it locked?
Old Jul 14, 2007 | 01:48 PM
shadow1's Avatar
I think I'm reading the whole ROM - I can see all the maps, etc.
Old Jul 14, 2007 | 01:55 PM
Planet Evo's Avatar
Well normally you can see everything, they just may be scrambled. Kind of stumped, sorry
Old Jul 15, 2007 | 12:30 AM
SICK9's Avatar
Sounds to me like someone changed the init code to 0001 to unlock the ecu and did the immobilizer by mistake and then changed the init code afterwards after they realized it .
Thats why I wrote my immo. code down and saved it in my desk drawer.
hmm? idk
Old Jul 15, 2007 | 12:33 AM
bigric09's Avatar
if your car is running with your immobilizer code set to 0001, then that is your code. What i'd do to confirm is start your car, make sure it runs. Turn it off, pull your map again, and then check the code. If its 0001 then thats what it is, if its something else, then you accidentally changed your code while looking at the tables or something.
Old Jul 15, 2007 | 04:34 AM
shadow1's Avatar
My car runs. That was never an issue. I guess my code is 0001. Does anyone know if the key code that comes on the little metal tag when you buy your car has anything to do with the immobilizer code?
Old Jul 15, 2007 | 05:35 AM
my-red-rs's Avatar
My key codes looks nothing like my Immobilizer code.
Old Jul 15, 2007 | 06:35 AM
shadow1's Avatar
the 5 digit key code would presumably need to be converted to a 4 digit hexadecimal value. What's your key code and I can convert it for you.... Then we can compare it to the Immobilizer code.
Old Jul 16, 2007 | 08:05 AM
EVO8emUp's Avatar
The little metal tag with the numbers is for cutting a new key.
