can't read ECU, need help
Old Jul 22, 2007 | 08:20 PM
kittio's Avatar
I've used ecuflash for a month and got some good experience until my last map. I'm not sure what mistake I did cuz I can't connect to the ECU anymore, the log said "(FFFF) unknown code" which I can't read and write to the ECU. Someone knows how to fix it?please help
Thx
PS 1. my car is Evo 9, JDM
2. evoscan is still working.
3. My program n cable can work with other evo.
Old Jul 22, 2007 | 08:27 PM
Vishnu_Evo8's Avatar
ecu got locked? how many times have you flashed it?
Old Jul 22, 2007 | 08:31 PM
kittio's Avatar
less than 10 times
Old Jul 22, 2007 | 08:40 PM
Ph3n1x's Avatar
Uninstall and reinstall ECUFLASH.
Reflash your base stock map back on it.
Old Jul 22, 2007 | 08:52 PM
kittio's Avatar
I reinstalled it but still can't flash the base map to ECU, the log said "unlnown code".
Old Jul 22, 2007 | 08:55 PM
awddyno's Avatar
I had the same thing happen. Usually you can only hear one click when you start to read the ecu. But I kept getting 2 clicks then it throws the unknown code. I tried running the unlocker in the back ground but still the same issue. Then after the 4th or 5th try it just worked. ????
Old Jul 22, 2007 | 08:59 PM
Ph3n1x's Avatar
Unistall, Restart the machine, Reinstall, Then insert cable and try.
Old Jul 22, 2007 | 09:22 PM
kittio's Avatar
yes, the same problem, hopefully will work again as you.
will try it, thx
Old Jul 22, 2007 | 09:25 PM
burgers22's Avatar
Hi
Evo Ix s are known to have a problem with low battery voltage causing a failure to connect. Also if the Tactrix cable has some loose pins this will cause the same problem.
MB
Old Jul 23, 2007 | 12:02 AM
kittio's Avatar
tried 2 times and the result are the same.
Old Jul 23, 2007 | 12:09 AM
kittio's Avatar
Originally Posted by burgers22
Hi
MB
the battery is still OK, 13.93V, and the tactrix cable is OK too. I will bring mycar to Mitsubishi dealer for checking the two conector, OBD and the small one.
thx,anyway
Old Jul 23, 2007 | 12:17 AM
burgers22's Avatar
That looks like quite a high battery voltage. Did you measure that with the engine running?
Did the last map you flashed come from a tuner or another source? Have you tried the ECU unlocker program?
MB
Old Jul 23, 2007 | 01:06 AM
kittio's Avatar
MB
No, the last flashed was fq map. BTW how do I get the ECU unlocker programme?
Thx
Old Jul 23, 2007 | 01:12 AM
burgers22's Avatar
Did you flash the whole ROM ( which is a bad idea ) or just the maps?
ECU unlocker at www.aktivematrix.com
MB
Old Jul 23, 2007 | 01:17 AM
kittio's Avatar
the whole ROM, I asked my bro to copy only the map but he did flash the whole.
